Hi All
I've checked the what's new for Inventor 2014 and the way I understand their explanation about the Autodesk 360 drive is the following.
This I understand and have no problem with
Here's the issue
The drive is also built into Inventor's Place component Dialog as a search location (see attached pic).
So...
Should it not automatically find the shared parts as they are loaded from a location that is shown as a search location?
Hi Paul
I had to do that to get the workflow to work... but the What's new doccumentation gave me a different impression.
Quote from the what's new doccument.
"You can Open from and Save files to Autodesk 360 from the top of the locations panel in file dialog boxes such as the Save As, Save Copy As, Open, Place Component and Create Component dialog boxes. Autodesk 360 is available in all file dialog boxes that include a locations panel."
What is the point of having it mapped by default (as in the screen shot) if you have to go and manually map it again?
