Is there a way to determine, by file search, what version of Inventor an Inventor model was created with?
Example: I have some older files in vault that were created with Inventor 2005 and 2008. Is there an advanced search criteria I could use to list out which of these files was created using either version?
Solved by johnsonshiue. Go to Solution.
iProperties of the file will show the version and SP level:
Hi! This can be done easily with Design Assistant. Go to Start Menu -> All Programs -> Autodesk -> Autodesk Inventor xxxx -> Design Assistant.
Start Design Assistant and open a folder. Then go to View -> Customize -> add "Last Update With" column. You will see the Inventor release and build last used to save the file.
Thanks!
I love knowing this BUT - I request Autodesk just have that already set that way for everybody out of the box...
Hi! You don't need Design Assistant to see the information. You can right-click on a given Inventor file (ipt, iam, idw/dwg, ide, and ipn) -> iProperties -> Detail.
If "iProperties" is missing from right-click context menu, please take a look at the following page.
https://forums.autodesk.com/t5/inventor-forum/missing-iproperties-on-right-click-menu/td-p/6720791
Many thanks!
