Inventor General Discussion
Active Contributor
dias_ryan
Message 1 of 8 (355 Views)
A Union Command?
355 Views, 7 Replies
05-29-2006 06:06 AM
I have an assembly file, i would like to creat a single solid from all the individual parts to find a volume.
Is there a way to do such a task?
*Cory McConnell
Message 2 of 8 (355 Views)
Re: A Union Command?
05-29-2006 06:09 AM in reply to: dias_ryan
Look into DERIVED COMPONET in the help. This will do what you want.
Cory McConnell, AICE
www.mechanixdesigns.com
wrote in message news:5188567@discussion.autodesk.com...
Distinguished Contributor
duncan
Message 3 of 8 (355 Views)
05-29-2006 06:12 AM in reply to: dias_ryan
Yes.
Open a new part file. Finish the sketch and then delete it in the browser.
Go to the Tool Panel and select Derive (it's near the bottom) the select the assembly you want to derive into the part. You can choose which parts to include or all of them.
Once the link between the derived part and it's origin has been broken it can't be re-made. but you can suppress or suspend the link and un-suppress or un-suspend later
HTH
Duncan
@home :smileyhappy:
Duncan Anderson
"Humour is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad as what passes for ordinary living." {Terence 'Spike' Milligan KBE (16 Apr 1918 – 27 Feb 2002)}
*Expert Elite*
JDMather
Message 4 of 8 (355 Views)
05-29-2006 06:17 AM in reply to: dias_ryan
Don't need to delete the sketch. When you exit the default sketch and start the Derived Component commad Inventor automatically removes the empty sketch. (The only time it does.)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
dias_ryan
Message 5 of 8 (355 Views)
05-29-2006 06:33 AM in reply to: dias_ryan
thanks guys.
*Lester Martin
Message 6 of 8 (355 Views)
05-29-2006 08:11 AM in reply to: dias_ryan
Is the volume of the assemble all you want?
If it is,
In the browser click on the top assembly, RMC and select iproperties select
the Physical tab, change the requested accuracy to Very High.
click update.
then you see the volume.
A number like this 1.839E+003 in^3 means there are 1839 cubic inches in the
assembly.
*Duncan Anderson
Message 7 of 8 (355 Views)
05-30-2006 12:33 AM in reply to: dias_ryan
wrote in message news:5188582@discussion.autodesk.com...
Thanks, I forgot about that because I have the origin projected.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
shekarsub[Autodesk]
Message 8 of 8 (355 Views)
05-30-2006 04:12 AM in reply to: dias_ryan
In R11, if the origin is the only projected geometry it should delete it in the derived component is what I gather. Thanks.
shekar
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
