Inventor Forum
A Union Command?
7 REPLIES 7
Message 1 of 8
dias_ryan
1902 Views, 7 Replies
A Union Command?
I have an assembly file, i would like to creat a single solid from all the individual parts to find a volume.
Is there a way to do such a task?
7 REPLIES 7
Message 2 of 8
in reply to: dias_ryan
Look into DERIVED COMPONET in the help. This will do what you want.
Cory McConnell, AICE
www.mechanixdesigns.com
wrote in message news:5188567@discussion.autodesk.com...
Message 3 of 8
DuncanAnderson
Yes.
Open a new part file. Finish the sketch and then delete it in the browser.
Go to the Tool Panel and select Derive (it's near the bottom) the select the assembly you want to derive into the part. You can choose which parts to include or all of them.
Once the link between the derived part and it's origin has been broken it can't be re-made. but you can suppress or suspend the link and un-suppress or un-suspend later
HTH
Duncan
@home 🙂
Duncan Anderson
"Humour is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad as what passes for ordinary living." {Terence 'Spike' Milligan KBE (16 Apr 1918 – 27 Feb 2002)}
Message 4 of 8
JDMather
Don't need to delete the sketch. When you exit the default sketch and start the Derived Component commad Inventor automatically removes the empty sketch. (The only time it does.)
Message 5 of 8
dias_ryan
thanks guys.
Message 6 of 8
Is the volume of the assemble all you want?
If it is,
In the browser click on the top assembly, RMC and select iproperties select
the Physical tab, change the requested accuracy to Very High.
click update.
then you see the volume.
A number like this 1.839E+003 in^3 means there are 1839 cubic inches in the
assembly.
Message 7 of 8
wrote in message news:5188582@discussion.autodesk.com...
Thanks, I forgot about that because I have the origin projected.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
Message 8 of 8
In R11, if the origin is the only projected geometry it should delete it in the derived component is what I gather. Thanks.
shekar
