Inventor General Discussion
*Rick Donnellon
Message 1 of 9 (331 Views)
A Solid Black Triangle That covers half of the sheet in an IDW?
331 Views, 8 Replies
06-27-2007 12:46 PM
Can anyone tell me what is the cause of this and how to fix it
XP Pro
IV 10 & 11 with latest SPs
DELL M90
Quadro FX 2500M
4 GIGS RAM
mcgyvr
Message 2 of 9 (331 Views)
Re: A Solid Black Triangle That covers half of the sheet in an IDW?
06-27-2007 01:02 PM in reply to: *Rick Donnellon
Try a different video card driver.
or use OpenGL instead of direct3d (or the other way around if using OpenGL already)
(search for "black drawing" brings you to some previous posts about it)
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
*Blair Stunder
Message 3 of 9 (331 Views)
06-27-2007 01:41 PM in reply to: *Rick Donnellon
There is a new driver posted on the Dell support website, it's not on the
current ADSK "Certified" list. Driver was released the first part of June.
Might solve your problem. I don't get any "Cert" warnings when running under
the Direct3D mode. Panning the screen in the IDW format will get ride of the
"Diver Down" flag on your display. Unless you use a "mod'd" Nvidia driver
such as the 91.36 version, you are stuck with the Dell site listed drivers.
You can check out Mod'd drivers at: www.laptopvideo2go.com
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
FX3400: Driver: 91.85
IV2008, SpacePilot 3.3.2
wrote in message news:5640649@discussion.autodesk.com...
already)
swalton
Message 4 of 9 (331 Views)
06-27-2007 03:36 PM in reply to: *Rick Donnellon
this has existed for at least 18 months (that I have used IV 10 and 11).
It does not seem to be a priority for fixing with Adesk or Nvida.
Inventor 2014
Vault Professional 2014
dreizehn
Message 5 of 9 (331 Views)
06-27-2007 03:59 PM in reply to: *Rick Donnellon
I am running the same laptop with the same hardware and have noticed this in the past as well. I have found that by closing the file and reopening it the problem will go away. I have just updated from IV11 to 2008 but have not worked with an idw yet. I am finishing up with a project now and am interested to see if the problem still exists.
cyberslinger
Message 6 of 9 (331 Views)
05-30-2008 07:35 AM in reply to: *Rick Donnellon
My company is also having the half black triangle problem. The one difference is we cannot pin point the problem. We have 30 new HP machines all identical, but there are only a handfull of them that have this problem.
All the machines were Ghosted so the software is all identical also. Why do some have the problem and others don't?
Specs:
Nvidia Quadro FX3500 256mg
Drivers 91.36
openGL
Microsoft XP X64 Professional OS
4 gig memory
Inventor11
andrewiv
Message 7 of 9 (331 Views)
05-30-2008 07:41 AM in reply to: *Rick Donnellon
I never found a permanent solution to the problem, but when we were on IV11 this happened to a few people and the only thing I found that worked was to switch back to the model and pan until nothing is visible in the view. Switch back to the idw and the triangle is gone. Not sure why it works.
Inventor Professional 2014 SP2
Vault Professional 2014 SP1
Windows 7 64 bit
Distinguished Contributor
smjanows
Message 8 of 9 (331 Views)
05-30-2008 08:12 AM in reply to: *Rick Donnellon
I noticed this previously on a machines running the /3GB option in XP Pro. The problem occured in Direct3D but not in OpenGL for me. The problem occured with both FireGL V3100 and Quadro FX1500 cards and various driver flavors.
I am not sure if the problem still exists in 2008 and newer as I have since upgraded to Vista Enterprise 64.
Other posters mentioned they are using XP 64. So my /3GB theory does not hold water there. But as I mentioned, the problem for me at least has disappeared with IV2008 / Vista64.
*Michael Puschner
Message 9 of 9 (331 Views)
05-30-2008 12:55 PM in reply to: *Rick Donnellon
Did you try this hotfix?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10331975&linkID=9242019
Michael Puschner
www.scholle.de
schrieb im Newsbeitrag
news:5944516@discussion.autodesk.com...
Specs:
Drivers 91.36
openGL
4 gig memory
Inventor11
