When you created your version of the Feed Rod Bearing you created two sketches and then extruded from them. Sketch 1 you used FIVE times.
How did you do that?
When I create a sketch then go to extrude, the extrude process consumes that sketch and I cannot re-use it.
How did you make those sketches available for re-use at will?
Solved by -niels-. Go to Solution.
Expand the feature, right-click on the sketch and select "share sketch".
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
