So I'm designing a racecar, just for fun and to see if I can do it. But I'm having problems with getting the front wheels straight.
At the moment the wheels are connected to a hub that is connected via ball joints with the wishbones. So to allign the wheels you have to allign these hubs. I've tried using the allign option in the ball joints, but there is no way I can get them straight. I've tried to use all the faces on these hubs but none give the right allignment.
Any suggestions how I can get this to work? As you can see the front whishbones are a bit too long, so I need to allign the wheels to calculate how much shorter they should be.
Solved by JDMather. Go to Solution.
Can you attach your assembly here
or here A360
Here is some reference information - look for the link for the class handout.
https://events.au.autodesk.com/connect/sessionDetail.ww?SESSION_ID=5792
Here's the assembly file with all the used parts, it was too big to add on here so here's a Dropbox link: https://dl.dropboxusercontent.com/u/55282876/project1.rar
Don't pay attention to the dimensions etc, it's all guessed and made up, like said it's just a project for fun.
I don't go to third party drop boxes.
I don't have an *.rar extractor.
Can you attach the assembly at your Autodesk 360 drive?
I understand that. I've put it in my 360 folder on my PC and it's syncing now. How do I share it with you now? When I click on 'Share' it wants me to fill in an email adress..
The easiest way is to make these three clicks - and a url you can post here will be generated.
or
my email is jmather_at_pct_dot_edu
Seems you can't share a folder publicly. So I zipped my projectfolder up now and now I could get a link.. I'll also share the folder via email, 'cause that does work.
I had trouble with your assembly because it did not appear that your sub-assemblies were constructed properly.
Every assembly (including sub-assemblies) should have one grounded component.
This defines the behavior of all other components within the assembly with remaining Degrees of Freedom (DOF).
When you place subassemblies (like your suspension assemblies) into the main assembly, you then right click on the subassembly and set to Flexible to preserve the DOF.
I am not sure what is causing the gray browser appearance - I saw this even in your ipt files.
For example,
there should be no relative motion of the wheel within it's assembly.
The Wheel should be grounded in that sub. I would prefer to have it centered at the origin.
After constraining the Tire and the Center Bolt, I would also Ground those components within this sub as there is no desired relative motion between the three parts.
Even if there is desired relative motion (DOF) between components - it should be defined relative to one grounded component or the assembly Origin planes and Axis.
Right so I grounded everything in the wheel assembly, and grounded the brackets of my suspension sub-assemblies. How do I now allign the front wheels? Still when I try to allign the front hubs they won't allign properly.
The gray browser was something that had to do with a dynamic simulation, it's solved in another topic:
Upload your new assembly to A360.
I have redone all my sub-assemblies and now I was able to allign the wheels. I follwed your advice on grounded components. However, in the wheel assembly I wasn't able to ground the tire and nut because then it gave errors with the joints or constraints so I only grounded the rim and used rigid joints to connect everything.
Thank you for your advice!
