I received a 3d model (enclosure) from a supplier, which was converted to an IPT part. For some reason, the colour of the part is wrong. Ideally the part is supposed to be yellow, but for some reason, blue colour is bleeding through and is visible in the PDF. How can I fix this?
Quality check, solid bodies and strip overrides.
Repair Environment
or
Construction Environment
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
