I still have a copy if you want to contact me at the email address below.
Do infants enjoy infancy as much as adults enjoy adultery?
IV 9 SP4 No extra Hotfixes
Win xp Pro SP2
Amd 3800 64 Bit
2 Gig Ram
Nvidia FX1000 7756driver
Corey Parks
Design Engineer
Metro Machine & Engineering Corp.
Eden Prairie, MN
cparks(A-T)metromachine(D-O-T)com
wrote in message news:5176384@discussion.autodesk.com...
Message stated about the hot fix (q328269_WXP_SP2_x86_ENU.exe). I am not
able to fin this anywhere on microsoft web site. Can anyone help.
This is suppose to be applied if you are running SP1 before the 3GB switch
is put in to place. Below is where I got thins info from
***WARNING***
Problems caused by improperly editing the BOOT.INI may prevent your system
from booting correctly and could render your computer operating system
unusable. Microsoft has provided a wealth of critical information you need
to know about the BOOT.INI file in the Microsoft Knowledge Base at
http://support.Microsoft.com/support.
Edit the BOOT.INI file only at your own risk and only after backing up the
original.
Example BOOT.INI file:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP
Professional" /fastdetect
Professional 3GB" /3GB /fastdetect
You should ensure that you have a total of at least 3GB set aside for the
Paging File Size to fully utilize the available address space. Also note
that every concurrently running application is sharing the available paging
file size, so setting to something more than 3 GB (such as 4 GB) is
recommended. In order to check the amount of memory you currently have
allocated follow these steps:
1) Press the Windows+Pause|Break keys simultaneously to gain access to the
System Properties
2) Click the Advanced tab, then, Settings button in the Performance group.
3) In the Performance Options dialog box click the Advanced tab and look at
the section titled Virtual Memory. The total amount of memory currently
allocated will be displayed here in megabytes
To ensure that Inventor is actually allocating memory in the 3 GB range,
start Inventor and then choose Help>About Autodesk Inventor. The first line
of text under the splash screen image should say: Autodesk Inventor
%release% - 3GB. If the - 3GB is shown, Inventor is successfully using the
feature; otherwise, it is not. (Releases prior to Inventor 6 SP2 have not
been enabled. Of course, the release number may vary.)
Limitations:
Executable files must be specially built to enable the larger address space.
The only Autodesk executable file shipped in the Autodesk Inventor Series to
be enabled to leverage the 3GB switch is Inventor.exe. Other executables
shipped with Autodesk Inventor have not been enabled. Most likely, the
applications provided by other software vendors have also not been enabled
to use this feature.
The feature only works on Windows XP. Furthermore, the Windows XP SP1
service pack had disabled it. To re-enable it for Windows XP SP1, there is a
hotfix from Microsoft that must be applied. (q328269_WXP_SP2_x86_ENU.exe).
This seem to be fine in SP2.
It is not possible to enable the feature on Windows NT, Windows 2000, or
Windows 9x.
Be aware that the OS now has less memory space. It is not completely clear
what implications that may have on Windows XP, but it would be wise to be
somewhat cautious with regard to the total application load placed on
Windows while running in this mode. If you donâ?Tt specifically need the
larger address space, it is recommended that you do not enable this option.
Only marginal performance improvement could occur on systems using swap
space on the systems hard disk to increase the available virtual memory
rather than using physical memory (1 gigabyte of physical memory and a 3
gigabytes swap file). A significant amount of time reading and writing
occurs when the system hard disk is used reducing the benefit of this
feature.
