I have a project I'm working on which requires a sweep path to be a graphical parametric mathematical function in x, y and z.
ex:
x=1.25*sin(10*t)
y=sin(t)*(12+1.25*cos(10*t))+12
z=cos(t)*(12+1.25*cos(10*t))
(this curve is a groove in the surface a bicycle tire. It spirals around several times and gets subtracted from a solid torus)
I was using an old version of NX I-DEAS and this task was easily accomplished with the "function spline" feature. Is anything like this possible in Inventor? I know I could create a list of points in excel, but I'd really prefer not to.
You will use the Spline in 3D sketch in Inventor.
Create the point set in Excel and import into 3d sketch with the option to create spline.
The CADWhisperer YouTube Channel
@Anonymous wrote:You will use the Spline in 3D sketch in Inventor.
Too my understanding, the spline does not associate with the Excel file. Is there an associative way to draw a curve based on a function?
How many points do you need to generate your curve.
No way that I know of to enter a formula to create curve directly.
If not too many - you could create user parameters, but if a lot of points....
There's a plugin for this, though I'm not sure how well it works.
http://labs.autodesk.com/utilities/pointlinker/
It makes an associative link to an Excel file.
@nannerdw wrote:There's a plugin for this, though I'm not sure how well it works.
That looks like just what I want, but every time I try it to use it, I get the following error prompt:
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040).
When I click the Details button, I see this:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileLoadException: The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) at PointLinker.PointLinker.Helper.ReadExcel(String fullFileName, ObjectCollection& oPtDataCollc, PointOptionEnum ptOp, Boolean is3D) at PointLinker.PointLinker.Helper.ImportNewPoints(String oFileName) at PointLinker.PointLinker.MainForm.BtnImport_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- WpfHost Assembly Version: 0.0.0.0 Win32 Version: 15, 1, 0000, 28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/WpfHost.DLL ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- msvcm90 Assembly Version: 9.0.30729.4148 Win32 Version: 9.00.30729.4148 CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e/msvcm90.dll ---------------------------------------- InvAIRLookContent Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/InvAIRLookContent.DLL ---------------------------------------- System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.1 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- PresentationFramework Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1500 built by: QFE CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- InvAIRLookContent.resources Assembly Version: 15.0.0.23900 Win32 Version: 15.0.0000.23900 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/en-US/InvAIRLookContent.resources.DLL ---------------------------------------- AdWindows Assembly Version: 3.0.270.0 Win32 Version: 3.0.270.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/AdWindows.DLL ---------------------------------------- InvAIRLookResources Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/InvAIRLookResources.DLL ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- PresentationFramework.Classic Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Classic/3.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- WpfAppPage Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/WpfAppPage.DLL ---------------------------------------- FlowRibbon Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/FlowRibbon.DLL ---------------------------------------- InvRibbonUIResources Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/InvRibbonUIResources.DLL ---------------------------------------- InvRibbonUIResources.resources Assembly Version: 15.0.0.23900 Win32 Version: 15.0.0000.23900 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/en-US/InvRibbonUIResources.resources.DLL ---------------------------------------- InvAIRLookImages Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/InvAIRLookImages.DLL ---------------------------------------- WpfAppPage.resources Assembly Version: 15.0.0.23900 Win32 Version: 15.0.0000.23900 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/en-US/WpfAppPage.resources.DLL ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 3.0.270.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/AdApplicationFrame.DLL ---------------------------------------- ManagedMC3 Assembly Version: 4.11.0.0 Win32 Version: 4.12.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/ManagedMC3.DLL ---------------------------------------- PresentationFramework.Aero Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- AssemblyBonusTools Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/AssemblyBonusTools.DLL ---------------------------------------- Autodesk.Inventor.Interop Assembly Version: 15.0.0.0 Win32 Version: 15.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.Inventor.Interop/15.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- AssemblyBonusToolsRes Assembly Version: 15.0.0.23900 Win32 Version: 15.0.0.23900 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/AssemblyBonusToolsRes.DLL ---------------------------------------- stdole Assembly Version: 7.0.3300.0 Win32 Version: 7.00.9466 CodeBase: file:///C:/WINDOWS/assembly/GAC/stdole/7.0.3300.0__b03f5f7f11d50a3a/stdole.dll ---------------------------------------- ADNPlugin-PointLinker Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Point%20Linker%20for%20Inventor/ADNPlugin-PointLinker.dll ---------------------------------------- Autodesk.Inventor.Interop Assembly Version: 13.0.0.0 Win32 Version: 13.0.0.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.Inventor.Interop/13.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll ---------------------------------------- Microsoft.VisualBasic.Compatibility Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll ---------------------------------------- Autodesk.iLogic.AddinLoader Assembly Version: 0.0.0.0 Win32 Version: 3.0.349.15 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/iLogicBin/Autodesk.iLogic.AddinLoader.dll ---------------------------------------- Autodesk.iLogic Assembly Version: 3.0.349.15 Win32 Version: 3.0.349.15 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/iLogicBin/Autodesk.iLogic.dll ---------------------------------------- Autodesk.iLogic.Common Assembly Version: 3.0.349.15 Win32 Version: 3.0.349.15 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/iLogicBin/Autodesk.iLogic.Common.DLL ---------------------------------------- Autodesk.iLogic.Interfaces Assembly Version: 3.0.349.0 Win32 Version: 3.0.349.0 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/iLogicBin/Autodesk.iLogic.Interfaces.DLL ---------------------------------------- CustomMarshalers Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll ---------------------------------------- CCAddIn Assembly Version: 0.0.0.0 Win32 Version: 15, 1, 0000, 28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/CCAddIn.DLL ---------------------------------------- Connectivity.InventorAddin.EdmAddin Assembly Version: 15.1.58.100 Win32 Version: 15.1.58.100 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/Connectivity.InventorAddin.EdmAddin.DLL ---------------------------------------- Connectivity.Proxies.Security Assembly Version: 15.1.58.100 Win32 Version: 15.1.58.100 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/Connectivity.Proxies.Security.DLL ---------------------------------------- Connectivity.Common Assembly Version: 15.1.58.100 Win32 Version: 15.1.58.100 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/Connectivity.Common.DLL ---------------------------------------- Connectivity.Common.Vault Assembly Version: 15.1.58.100 Win32 Version: 15.1.58.100 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/Connectivity.Common.Vault.DLL ---------------------------------------- EdmTranscriptWrapper Assembly Version: 0.0.0.0 Win32 Version: 15.1.58.100 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/EdmTranscriptWrapper.DLL ---------------------------------------- PresentationFramework.Luna Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll ---------------------------------------- LegacyPipeline Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/LegacyPipeline.DLL ---------------------------------------- CCCBL Assembly Version: 0.0.0.0 Win32 Version: 15, 1, 0000, 28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/CCCBL.DLL ---------------------------------------- CCServerProxies.Object Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0000.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/CCServerProxies.Object.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- Microsoft.Office.Interop.Excel Assembly Version: 10.0.4504.0 Win32 Version: 10.0.4504 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/iLogicBin/Microsoft.Office.Interop.Excel.dll ---------------------------------------- Iop Assembly Version: 0.0.0.0 Win32 Version: 15, 1, 0000, 28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/Iop.DLL ---------------------------------------- TreeControlDotNET Assembly Version: 15.1.0.28200 Win32 Version: 15.1.0.28200 CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202011/Bin/TreeControlDotNET.DLL ---------------------------------------- DevExpress.XtraTreeList.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraTreeList.v9.1/9.1.4.0__b88d1754d700e49a/DevExpress.XtraTreeList.v9.1.dll ---------------------------------------- DevExpress.XtraEditors.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraEditors.v9.1/9.1.4.0__b88d1754d700e49a/DevExpress.XtraEditors.v9.1.dll ---------------------------------------- DevExpress.Utils.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.Utils.v9.1/9.1.4.0__b88d1754d700e49a/DevExpress.Utils.v9.1.dll ---------------------------------------- DevExpress.Data.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.Data.v9.1/9.1.4.0__b88d1754d700e49a/DevExpress.Data.v9.1.dll ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
When I click the Continue button, nothing happens.
I've attached a copy of the Excel file that I am trying to import.
which version of Excel are you using?
I tested PointLinker with Inventor 2012, and Excel puts up an invisible dialog indicating the file has been updated because airship.xls was generated using an older version of Excel (I have Excel 2010 installed).
Whilst this dialog is waiting for input, the PointLinker import command freezes.
If I then open Excel - I see the dialog, and can click on save. The points are then imported as expected (and when I try again all works as normal once the airship file has been updated).
I'll ask the author to investigate - one possibility is that a call into the Excel API is failing because it is an old version.
Cheers
Gary Wassell
EMEA Manager - Developer Technical Services.
@gary.wassell wrote:Hi,
I am using "Microsoft Office Excel 2003 (11.8169.8172) SP3".
What is the function that you wish to model? Depending on what it is, there may be a way to get an "exact" representation of it in Inventor. For example, if your function describes a parabola, you can model a parabola by creating the proper cone and slicing it in the appropriate way (the same goes for any formula derived from a conic section, i.e. hyperbola, ellipse, or circle--though it obviously wouldn't be necessary for an ellipse or circle). Even if your curve isn't a conic section, there may be a way to model it with intersections of surfaces.
Post your formula if you would like some extra pairs of eyes on it.
@cwhetten wrote:What is the function that you wish to model? Depending on what it is, there may be a way to get an "exact" representation of it in Inventor. For example, if your function describes a parabola, you can model a parabola by creating the proper cone and slicing it in the appropriate way (the same goes for any formula derived from a conic section, i.e. hyperbola, ellipse, or circle--though it obviously wouldn't be necessary for an ellipse or circle). Even if your curve isn't a conic section, there may be a way to model it with intersections of surfaces.
What I am trying to do is draw one of the eight gores, or panels, that would make up a model blimp's envelope. The envelope shape is pretty simple, a revolved ellipse, but the gores have a more difficult to design shape. The length of each gore is equal to the arc length of the envelope going from end to end. The width of each gore varies across its length. This varying width is a function of the circumference of the envelope with respect to the position along the length of the envelope.
I can model the envelope and divide it into eight gores, but I am essentially trying to flatten one of the gores out so that I have something to feed to a CNC machine which can cut the mylar.
I believe the Excel file I shared has the forumlas in it already.
I'm not sure exactly what you are trying to acheive. You have successfully modeled the shape of the gore, and it's easy enough to extract one of them from the envelope model you posted.
Inventor won't automatically create a flat pattern of this shape, if that's what you are looking for.
Do you already know the (x,y) function of the flat shape? I guess I should look at the excel file you posted to see what you have already done.
@cwhetten wrote:I'm not sure exactly what you are trying to acheive. You have successfully modeled the shape of the gore, and it's easy enough to extract one of them from the envelope model you posted.
I suppose a summary is in order:
More succinctly, Point Linker does not work and I need help to make it work, please.
can you let me have your direct contact details (email them to gary.wassell@autodesk.com)?
We can then work with you directly to resolve the issue with PointLinker.
Gary
With the help of a/the Point Linker developer, I now have a working add-on. I suppose the community will see an update to Point Linker, but I will leave such a speculation for the developer(s) to confirm, deny, or neither. Many thanks!
@kpadilla wrote:
- I shared the .ipt file for the envelope divided into gores so that readers could better understand my posts.
Is there reason you didn't use the Origin and didn't use the existing Origin workplane and axis and instead re-created these?
Is there a reason your first sketch is missing horizontal constraint on the line and not fully constrained?
yes we'll post an update to the PointLinker app on Autodesk Labs in due course.
Cheers
Gary
@Anonymous wrote:Is there reason you didn't use the Origin and didn't use the existing Origin workplane and axis and instead re-created these?Is there a reason your first sketch is missing horizontal constraint on the line and not fully constrained?
I don't remember exactly why, but I probably started the sketch at the origin and then decided to try sketching differenly right below where I started. I think I originally tried to define the outline of the envelope parametrically with a spline, starting at the origin, but it got ugly, so I erased it.
To answer your second question, no, but I hope the part file helped to illustrate my posts as I intended.
