Inventor Forum
3D Sketch vs Sweeps
15 REPLIES 15
Message 1 of 16
mmiller1
1923 Views, 15 Replies
3D Sketch vs Sweeps
In Inventor R11, SP2 why :
(1) Why can't you use the Sweep command with a 3D sketch?
(2) Why can't you draw circles in the 3D sketch environment? What do you do if you need to sweep a cut with a circular profile along a 3D sketch line?
MIke
15 REPLIES 15
Message 2 of 16
JDMather
in reply to: mmiller1
1) I can and here is an example http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
2) A circle is a planar (2D) object - don't need a 3D sketch.
See above tutorial for 2nd part of question. You can create a workplane anywhere along a sweep path for the profile( or use one of the base workplanes if appropriate).
Can you post your file.
The CADWhisperer YouTube Channel
Message 3 of 16
mmiller1
Thanks for the info. The tutorial uses knot.ipt. Can I download this file somewhere?
Mike
Message 4 of 16
JDMather
Here is the file.
Of course you should also try recreating the sketches on your own. This one is simple sketches.
And you can also use Included edges from existing solids in the 3D sketch path. This particular tutorial doesn't demonstrate that functionality. 3D sketches can also be used for complex curve driven feature patterns (the Rectangular Pattern is really a misnomer - it can do much more than rectangular patterns). Post what you have so far if you have trouble with your design.
Message 5 of 16
mmiller1
Thank you.
I posted my file under the heading "Blanket.ipt" in CF. Instructions are included with the post.
Thanks!
Mike
Message 6 of 16
Thanks... You can post the files on this NG instead.. makes it easier for
people to follow a thread.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5581988@discussion.autodesk.com...
Thank you.
Thanks!
Mike
Message 7 of 16
mmiller1
I've been away from the Inventor Group for a while but it has always been customary / required of us to post files in CF. Is that still true?
Mike
Message 8 of 16
JDMather
No, a while back they changed the forum such that there is no compelling reason to post in CF.
Now if they would up the limit to say 5Meg over there and lower say 70k primarily for jpg here....
Message 9 of 16
On another issue, JD..... can you repost that link for students to get a
copy of IV?
260-399-6615
AIP 11SP2, AIP 2008
wrote in message news:5582030@discussion.autodesk.com...
Message 10 of 16
http://students5.autodesk.com/?lbon=1
Rob
Inventor 11 SP2 Build 344a
Vault 5.0 Build 11.1.145.0
ATI FireGL X2 AGP Pro
Graphics Driver: 8.223.0.0
(2 Monitors at 1280x1024)
Using Direct 3D
"Dennis Jeffrey" wrote in message
news:5582074@discussion.autodesk.com...
copy of IV?
260-399-6615
AIP 11SP2, AIP 2008
Message 11 of 16
JDMather
http://engineersrule.org
Right now only r10 & r11 are available but r2008 AIP should be available any day now. An edu email is required but those without an edu email can request a guest registration - that is one of the ways I recruit HS students.
or
http://firstbase.autodesk.com
Message 12 of 16
JDMather
Mike,
I didn't spend a lot of time analyzing your model primarily because it seemed to really bog down my machine and did not look like an actual part but rather something you were experimenting with.
A couple of quick things I did notice. A triangle is a 2D planar object so do as a 2D sketch. Always go for the simple solution.
When you thicken a surface that is not planar the edges are not planar so a sweep of the triangle is probably not going to give you the geometry you want. I would do a Loft using the two edges as rails.
Whenever I run into a part that seems to really slow down I start trying diffferent methods to achieve the same geometry without the slowdown.
You might check out these parts, particularly the Seat. Some of the parts I modeled at least a half a dozen ways - not because my first attempt didn't work but because I was not satisfied that I had found the mose efficient method.
http://home.pct.edu/~jmather/SpyGadget/HammerHead_Mather.zip
Some of the parts I would do over if I had the time. You can probably tell which ones.
Also if you are just experimenting to see what kind of complex geoemtry you can create you might want to go through these tutorials first
Message 13 of 16
d.boy
in reply to: JDMather
I know this thread has been inactive for a long time, but I can't seem to open/find the example you posted. Is there something simillar file available now?
Message 14 of 16
JDMather
in reply to: d.boy
What example? (I see a whole bunch of different references in this thread.)
Message 15 of 16
d.boy
Sorry, I should have specified. The first one that was sent:
1) I can and here is an example http://home.pct.edu/~jmather/content/DSG322/Invent​or%20Tutorials/Inventor%2011%20Tutorial%207.pdf
Message 16 of 16
JDMather
in reply to: d.boy
I prefer email to request these files jmather_at_pct_dot_edu
but it is attached here.
