I am wondering if anyone else has seen this, I created a 2D planar sketch, now I need to create a 3D sketch and Helical curves, but as I enter into the 3D sketch mode, I cannot perform any functions, all my tool bar options are grayed out?
I am running 2014 Pro Design Suite.
Thanks in advance.
Solved by JDMather. Go to Solution.
Did you reboot the computer and this behavior persists?
If you start a new file does this behavior continue.
BTW - I never use 3D sketch to create a helical curve - Coil is much easier and much easier to edit.
JD thanks again, I should have tried that first.
