Inventor General Discussion
0 Kudos
Post 1 of 5
3d sketch help pleeeeeeaaaaase
853 Views, 4 Replies
12-22-2011 06:19 AM
Hi
Im struggling to create the drawing which I require.
I've attached a couple of pics which show roughly what is required.
The problem Im having is when carrying out a 3d sketch, I would like the arc or even a spline to have a controllable radius in two directions.
Please take a look at my pics to help understanding easier.
I need to do this so that the curve sketched is equivalent of being drawn on a curved surface, I need good technique as I have numerous curves to draw, increasing in size the further away from the centre they get as I creating an impeller bladeCapturejkjkjkjkjk.JPGCapturenbbnnbnbn.JPG
Employee
8 Kudos
Post 2 of 5
Re: 3d sketch help pleeeeeeaaaaase
12-22-2011 09:43 AM in reply to: ryan.sanderson
Can you create two surfaces and get their intersection? (The first surface is a horizontal cylinder, and the second is an extrusion of a circular arc)
Udaya Gunasena
Fusion Development
267 Kudos
Post 3 of 5
12-22-2011 10:00 AM in reply to: ryan.sanderson
Something like this?  Extruding as surfaces isn't even necesssary.  Just create the two 2D sketches, then create a 3D sketch and intersect the first two sketches.
Attached file is 2012.
Distinguished Contributor
5 Kudos
Post 4 of 5
12-22-2011 11:29 AM in reply to: cwhetten
Would this 3D sketch then be patterned around the circle on sketch 1? Ryan mentioned the need for several arcs so I assume they would be arrayed around the circle.
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
0 Kudos
Post 5 of 5
12-22-2011 01:51 PM in reply to: ryan.sanderson
thanks for all your help guys, managed to get the desired effect, I drew two two 2d images and then used the 3d image to intersect the line. very clever great advice thanks
