Inventor General Discussion
Active Member
klapec
Message 1 of 4 (247 Views)
3D sketch from text
247 Views, 3 Replies
09-12-2012 03:40 AM
Hi
is it possible to create 3D sketch from text?
I need it for engraving as a toolpath and for drawings.
Emboss tool is more suitable for styling and visualisation.
Attached sample from Pro-E:
Active Member
klapec
Message 2 of 4 (198 Views)
Re: 3D sketch from text
11-16-2012 02:54 AM in reply to: klapec
Hi
nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
Autodesk Product Design Suite Ultimate 2013 SP1.1
Distinguished Contributor
SKinzel
Message 3 of 4 (170 Views)
11-16-2012 12:41 PM in reply to: klapec
In the model you can create a sketch and text is an option in the Draw panel.  Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object.  Then use the Export command to export a STP file.
If I understand correctly this is what you want.
See attached
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
Active Member
klapec
Message 4 of 4 (135 Views)
11-18-2012 10:34 PM in reply to: SKinzel
Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
Does anybody from Autodesk know how to fix it?
