Inventor Forum
3D sketch from text
3 REPLIES 3
klapec
423 Views, 3 Replies
3D sketch from text
Hi
is it possible to create 3D sketch from text?
I need it for engraving as a toolpath and for drawings.
Emboss tool is more suitable for styling and visualisation.
Attached sample from Pro-E:
3 REPLIES 3
klapec
in reply to: klapec
Hi
nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
Autodesk Product Design Suite Ultimate 2013 SP1.1
SKinzel
in reply to: klapec
In the model you can create a sketch and text is an option in the Draw panel.  Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object.  Then use the Export command to export a STP file.
If I understand correctly this is what you want.
See attached
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
klapec
in reply to: SKinzel
Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
Does anybody from Autodesk know how to fix it?
