Inventor Forum
3d sketch dimensioning
4 REPLIES 4
1057 Views, 4 Replies
Is there a way of dimensioning a 3D line in a certain plane? I have a line <3i,2j,5k> and want to dimension the j component only instead of the overall length. I've been creating a plane on the initial point and dimensioning the second point to that but I was wondering if there was an easier way.
4 REPLIES 4
Generally, 3D line dimesion is the true distance between the two end points
on the line. If you want to dimension with different components, you need to
either create a workplane or make the origin workplanes invisible. Then
dimension by selecting the point and a workplane.
I think what you have been doing is correct.
Thanks!
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5715981@discussion.autodesk.com...
Sorry to bring this post out of the mothballs, but the ability to dimension a 3D sketch point to a work plane is new to me.
I've done some experimenting (IV2009), and it doesn't appear possible to dimension a skew line to an origin or work plane (to control the absolute angles from horizontal, vertical, etc). I know Inventor can figure the angle, because the measure angle tool brings up the correct number instantly.
Is there a method to accomplish this that I'm missing, or is this functionality still not available? I know how to accomplish this with 2D Sketches, but I'm testing to see if a 3D sketch alone can control geometry in this manner.
johnsonshiue
Hi! You got a good point here. I am forwarding your request to product design.
Thanks!
Software Test Engineer
