Yeah, think you can do that.
In the 3D sketch command,
pick the sketch point command,
pick the place on the line you want the point,
then pick the crossing Origin plane (in the browser) to place the point.
Exit the 3D sketch command,
start the workplane command,
pick the point,
pick the line,
finish the command.
Should have a workplane on the point.
~Larry
"ncabilan"
wrote in message
news:4859836@discussion.autodesk.com...
Johnson, i tried it here at home and i think i'm still missing something. i
know i can attached points and make workplanes along a 3d sketch line. my
question is can this also be done along a 3d line that is created from the
intersection of two surfaces. see attached.
"Johnson Shiue [Autodesk]" wrote in message
news:4859173@discussion.autodesk.com...
Normal to Path workplane: Workplane tool->pick the 3D line and pick one of
the end points on the
3D line.
You can pick any point to place a workpoint.
Let me know if more information will be needed.
Thanks!
Johnson Shiue
Test Engineer
Autodesk, Inc.
"ncabilan" wrote in message
news:4859088@discussion.autodesk.com...
Is there a way to add workpoints/workplanes on a 3d line made from two
intersecting extruded surfaces?
ncabilan
