Inventor Forum
3D Monitor/TV/Projector
9 REPLIES 9
Message 1 of 10
Raider_71
2604 Views, 9 Replies
Hi guys is there a way of viewing your Inventor models in full 3D on a 3D TV/Monitor/Projector? Obviously with a quadro VGA Card and glasses... Is it posible and how can this be set up?
Pieter
9 REPLIES 9
Message 2 of 10
Doug_DuPont
in reply to: Raider_71
You might to check this out.
You have to take your model into Showcase.
http://labs.autodesk.com/utilities/showcase_ar
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Message 3 of 10
Ryan.Martinez
in reply to: Doug_DuPont
I saw something like this at AU last year. It was a walk through of a bus and you used an xbox control to move your P.O.V. around. I don't remember the name of the software though.
P.D.S. 2015
P.D.S. 2016
Message 4 of 10
Raider_71
The thing is that we have a 3D projector with glasses and when we start Inventor it sees it as a 2D image. Is there a setting or something you can set to enable the 3D vision? I am new to this so dont know where to start.
The whole setup works well with 3D movies etc but how to convert the Inventor 3D model to be the correct source...
Message 5 of 10
DarrenP
i think you would have to use other software like showcase, 3ds max or maya
or a 3rd party add on for inventor if there is one
DarrenP
Message 6 of 10
Raider_71
Hi thanks for all the replies so far but it sounds like this is not done easilly. I find it hard to believe that you cannot use a 3D TV or Projector with a 3D application like Inventor.
Message 7 of 10
Ryan.Martinez
There are more important things that need to be fixed with inventor before AD adds features like this.
P.D.S. 2015
P.D.S. 2016
Message 8 of 10
DarrenP
in reply to: Ryan.Martinez
if you have product design standard or higher you have access to showcase
DarrenP
Message 9 of 10
mrattray
Just because it's a 3D model doesn't mean it can be displayed in 3D. As similar as the two things may sound, they are actually quite different.
Mike (not Matt) Rattray
Message 10 of 10
Raider_71
I see it looks like Navisworks and Showcase has a stereoscopic output function. Anyway its a pitty Inventor doesnt support it.
I will keep on digging and see what I find.
