Hello everybody,
Does anyone know where I can obtain a 3D model of a plastic toggle clamp.
I am currently designing a set of moulds for casting resin medical components and I need to be able to hold the 2 box parts together with a standard lever action clamp on either side.
It’s the sort of thing one sees on dozens of different items every day from simple tool boxes to air-tight food containers.
Any suggestions would be greatly appreciated.
Thank you.
CJJ
@CJ.10E-10mm wrote:
Hello everybody,
Thank you.
CJJ
And there is only a million different variations on a "toggle clamp"..
One might suggest finding the manufacturer or a site that sells the exact one you want and offers a 3d step/iges file to download..
mcmaster sells lots of mechanica stuff and has 3d models of most of it.. maybe soutchco... maybe misumi.
maybe this one http://grabcad.com/library/overcentre-toggle-clamp or similar sites like that..
Dear mcgyvr,
Thank you, the linked item is a bit too heavy duty for my requirements. But thank you for taking the trouble all the same, I am most grateful.
In the event no alternative solutions are forthcoming, it seems that I will have to endeavour to purchase a product fitted with a suitable plastic toggle clamp and physically scan it and introduce it into Inventor as an image.
Thank you once again.
cjj
autodesk.partcommunity.com
Examples of suppliers:
- Elesa+Ganter
- DE-STA-CO
Hi paul.huppertz,
Thank you for your kind suggestions. Unfortunately they only offered high performance metal clamps.
This in turn made me stop and think more of the practicality of the project; namely that I didn’t want to risk vibrating the mold assembly and thus decided upon a more traditional fine bolted fixing.
So I opted to produce matching projecting flanges in which I was able to insert M8 threaded brass inserts reference FSUK-PUH from the underside.- http://www.fasteningsolutionsuk.com/?page_id=120.
8mm threaded insert into bottom flange. This enabled me to apply a simple M8 Thumb Screw for easy screw tight installation. http://www.wdsltd.co.uk/product/3553/thumb-screw-303-stainless-steel-wds-8917
Stainless Steel Thumb Screw.
This is the end result.
So a big thank you to both Paul.Huppertz and mcgyvr for their kind and valuable assistance.
Without help from fellow colleagues my learning curve would be far more protracted and fragmented.
So a big thank you to all those that have helped me in recent months.
cjj
