Inventor Forum
3D Model exporting to 3D Studio Max
11 REPLIES 11
Message 1 of 12
1840 Views, 11 Replies
So my marketing department has been bugging me about being able to use my 3D models in 3D studio max, we tried just a straight transfer as and iam file and we got an error message: “The inventor file could not be opened for import. Try opening the file in Inventor to see what is wrong. The last version of Inventor.exe that opened is what is used for the importer. Make sure you are using the correct version, or a newer one.”
Any thoughts, hints or tricks would be greatly appreciated.
Joe
11 REPLIES 11
Message 2 of 12
JDMather
What version of Inventor?
Does 3D Studio Max read dwg (I would certainly assume) or STEP?
Save As>Save Copy as
or Environments>AEC Exchange>Save as DWG Solids
Message 3 of 12
in reply to: JDMather
I'm running 2012 fully updated with SP1.
Files that 3D Studio Max accepts include:
3D Studio Max Native file format is .MAX
Autodesk Inventor (IPT, WIRE, IAM)
3D Studio Mesh (3DS, PRJ)
Autodesk (FBX)
Autodesk Collada (DAE)
AutoCAD Drawing (DWG, DXF)
IGES (IGE, IGS, IGES)
dwg does't help as much as it comes in 2D form and the real goal is for them to have a 3D model to be able to do fly bys and what not. Step is not included on the list of accepted formats.
Joe
Message 4 of 12
swalton
I was able to get 3DS Max from the new suites to import IV 2011 and IV 2012 ipt and iam files with minor issues.
The main issue was that my IV models were too detailed and overloaded 3DS Max.  Not unexpected because we model every washer, nut and bolt for our train assemblies.  I think we got to 10-12 million triangles in Max.  Our marketing folks wanted models no bigger than 8k.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 5 of 12
JDMather
Saving as DWG solid opens in AutoCAD as 3D?
IGES was in your list.
Of course it would be ideal to figure out why it isn't opening iam directly.
Message 6 of 12
mcgyvr
start with a small ipt or iam and see if that can be opened by 3ds
Message 7 of 12
in reply to: mcgyvr
Could it be a compatability thing? Cause its IV12 vs. 3DSM 2011?
Message 8 of 12
JDMather
Sounds like a problem to me (Inventor isn't backward compatible, so Inventor2012  to 3DS 2011?????)
But IGES or dwg should work.
Message 9 of 12
swalton
I would assume so.  I doubt that Adesk has released a patch so that 3Ds Max 2011 can understand IV 2012.  Remeber that IV 2011 can't understand IV 2012.
Try 3DS Max 2012 or the other file types.  You should have a copy of 3DS Max 2012 with your IV 2012 product suite.
Steve Walton
Inventor 2023
Message 10 of 12
IS200
in reply to: swalton
In my experience...
Check for broken constraints/sketches, turn of adaptivity in all parts, basically make sure your assembly is squeaky-clean in Inventor first. I don't think it matters which version of Inventor/Max you have. I've imported models between different versions in the .ipt/.iam format with no hassles. Unless it has changed in recent releases it shouldn't matter which version of Inventor/Max you have because Max will start the Inventor process to do the import regardless of what version it is.
Hope this helps
dL
Message 11 of 12
patrick.miller
in reply to: IS200
I'm trying to get confirmation, but I believe the posts above are correct: you cannot import Inventor 2012 into Max 2011. My understanding is SAT would be the next recommendation. See the links below from the MAX online help.
SAT import help
Inventor import help
Patrick Miller
User Experience Designer
Fusion 360 Learning
Message 12 of 12
If you upload a new version of inventor (ex. 2015 to 2019 ) before merge or open your file to 3dmax you have to uptade your model to inventor. Ex. you upload new 2019 to your computer but you never uptade your old assamble parts to your new ınv19 . by the way when you open ur old file to new inv2019 old content center materials gone and it gives you alert. and if you open your file on max before updating you will get some boring messages.. l have same problem now l solve. l gave 4 days to solve this problem .. when you work in inventor be sure your model have no problem. like skect or referance asembble or dimension etc.and up to date if you do anythng . be sure everthing is okay on your inv. then after you can merge correctly. no missing part no scale errors. and be sure if you work in mm on inv , your max unit must be mm ..
