I've currently got a 3DConnexion SpacePilot PRO but I've found the setup process to be arduous to say the least. Their latest update wiped my profile so now I'm back at square one, having been told that I need to learn XML to restore some of the previous functionality...
My question is: What other 3D mice have people used and what were their thoughts on them? SpaceControl have some interesting looking units and I'm sure there's other brands out there too. I like to be able to configure my button setup to open programmes that I commonly use, and also change the mapped commands to suit.
Thoughts? Anyone?
The main issue I have is with the setup. I know that the application command files are supplied by the software vendors, so it's partly a AD issue, but when setting up custom key bindings, I have to wade through a dozen different commands, all labelled 'Open', until I find the one that works in the particular context I'm after. Add to that the latest software update that removes native support for mapping startup of common applications (such as IV) from the GUI, (The user now has to write a custom XML file to get the same functionality) and you can see why I might be a little frustrated. The update also deleted my existing profiles, so I'm starting again from scratch after spending a year tweaking things to my liking...
Like Blair, I have NO problems either. Its a simple device with simple setups..
Slow down..take a breathe.. must of had a bad day with it.. tomorrow will be better 🙂
I used to use a Space Explorer, and found that I simply didn't use the buttons, so on this last hardware upgrade I chose the Space Mouse Wireless. Smaller, simpler, no buttons, just a 3D mouse.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
A spent some time on the phone with 3dConnexion last week. I worked through how to customize Inventor with the new V10 drivers and redeploy to my users. It's not simple, but it should only require copying a copy files. I'll write a batch file to do it. I haven't had a chance to try it yet but will report back my experience.
Here are the alternatives I know of...
And this company, but not sure they're in business anymore...
-Brian Cranston
