Inventor Forum
3D Line Grayed Out - Not Working
4 REPLIES 4
iUser
1098 Views, 4 Replies
Hi Guys,
I am trying to use the 3D line tool in the Pipe and Tube section. I am using Inventor 2014 S1 and this tool is grayed out and I can't select it? The auto route doesn't follow the route that I want. Any advice will be much appreciated.
4 REPLIES 4
JDMather
in reply to: iUser
Note that the Green tab is your Route tab (active tab).
The 3D sketch tab is not active.
I think you need to go into an active 3D sketch, create it, and then go back to your Route to select it.
iUser
in reply to: JDMather
I don't understand? How do you go into an active 3D sketch? Or how do you create a 3D sketch? Because I can't find that tool? The only 3D sketch option that I get is when I create a new pipe route, then the 3D tab appears and I can then select it. But then the line tool is grayed out?
cbenner
in reply to: iUser
bob_holland
in reply to: iUser
iUser,
To create a 3D Sketch, select the down arrow next to Create 2D Sketch.
It will then give you the option to Create 3D Sketch.
Have a good day.
Bob Holland
Autodesk Product Support
