I'm not sure if this will help . . . . but here goes. I had a difficult concetina part to create . . . . . radii, angles etc. I couldn't sketch in Inventor. Had to draw it in Autocad (2d) copy and pasted into Inventor ( sketch mode )
@scorpion52 wrote:I had a difficult concetina part to create . . . . . radii, angles etc. I couldn't sketch in Inventor. Had to draw it in Autocad (2d) copy and pasted into Inventor ( sketch mode )
Attach the file here.
@scorpion52 wrote:Thanks JD Mather,I was just answering mooresk257's question for a simple way. I'm better at Autocad than Inventor.
You did not answer the questioin with an easier way of opening an AutoCAD 3D in Inventor - I suspect your technique is actually much more work - that is why I requested your file that you think is easier to sketch with AutoCAD.
Also, this is a very old thread - I suspect the OP had solved the problem by now.
