"v.valentijn" <Adding
href="mailto:v.valentijn@ithema.nl">v.valentijn@ithema.nl> wrote in
message
href="news:6F7011FA4E534C77C74584371F23359A@in.WebX.maYIadrTaRb">news:6F7011FA4E534C77C74584371F2......
a sketch in the plane where I want to have the dimension doesn't
work! I
have projected the desired project-geometry but I get an
errormessage [they
call it Inventor tip?] saying: cannot constrain or
dimension reference of
fixed geometry.
Someone please help.. why can't I seem to add this
measurement to my
parameters?? In helpfiles I can only find dimesions in 2D
sketches, does
this mean that is the -only- place where I can dimension and
deduce
parameters?
"v.valentijn" <
href="mailto:v.valentijn@ithema.nl">v.valentijn@ithema.nl> schreef in
bericht
href="news:CE695B362DE55045E01DF9FCFD2CDF78@in.WebX.maYIadrTaRb">news:CE695B362DE55045E01DF9FCFD2......
I would like to measure a distance between a workplane and a parallel
workaxis and make this into a parameter [which is preferably but not
necessarily editable]. How can I do this? I tried constructing a
workplane
> running through the workaxis, perpendicular to the workplan,
in order to
> attach the desired dimension there.. but it won't work
with an empty
sketch.
> ~ I've considered making a sketch there,
constraining it to the 3D model
> and -then- adding the
dimension.
> But I consider there must be a much more straight forward
solution to
this?
"RuiF" <rui.cad@netcabo.pt>
schreef in bericht
href="news:7192E4FEA44F42D2DFF04A71E3A0CA63@in.WebX.maYIadrTaRb">news:7192E4FEA44F42D2DFF04A71E3A......
Have you tried adding the line, but only
constraining one endpoint.
Then add a driven dimension and finally
constrain the other endpoint.
This should allow you to use the driven
dimension as a parameter.
Rui
message
href="news:6F7011FA4E534C77C74584371F23359A@in.WebX.maYIadrTaRb">news:6F7011FA4E534C77C74584371......
work! I
errormessage
[they call it Inventor tip?] saying: cannot constrain or
dimension
reference of fixed geometry.
add this measurement to my
dimesions in 2D sketches, does
can dimension and deduce
parameters?
"v.valentijn" <
bericht
href="news:CE695B362DE55045E01DF9FCFD2CDF78@in.WebX.maYIadrTaRb">news:CE695B362DE55045E01DF9FCF......
parallel
preferably but not
constructing a workplane
to the workplan, in order to
but it won't work with an empty
sketch.
a sketch there, constraining it to the 3D model
> and -then- adding
the dimension.
forward solution
to
this?
"v.valentijn" <
message
href="news:7F56740B26893B35862E422B140583CB@in.WebX.maYIadrTaRb">news:7F56740B26893B35862E422B140......
I had tried that before I posted.. but it gave me
the same 'error' still.
BUT after your suggestion I thought I'd try again
and now I found out that somehow it -won't work- if I draw the line from
endpoint to endpoint [giving the error] and it DOES work if I draw the line
from endpoint to midpoint [giving me the option to add a driven dimension] AND
That will do just fine for me!
so Thanx a lot!
"RuiF" <
href="mailto:rui.cad@netcabo.pt">rui.cad@netcabo.pt> schreef in
bericht
href="news:7192E4FEA44F42D2DFF04A71E3A0CA63@in.WebX.maYIadrTaRb">news:7192E4FEA44F42D2DFF04A71E......
Rui
message
href="news:6F7011FA4E534C77C74584371F23359A@in.WebX.maYIadrTaRb">news:6F7011FA4E534C77C745843......
work!
I have projected the desired project-geometry but I get an
errormessage
dimension
I can dimension and deduce
parameters?
"v.valentijn" <
in bericht
href="news:CE695B362DE55045E01DF9FCFD2CDF78@in.WebX.maYIadrTaRb">news:CE695B362DE55045E01DF9F......
parallel
preferably but not
tried constructing a workplane
perpendicular to the workplan, in order to
> attach the desired
dimension there.. but it won't work with an empty
sketch.
I've considered making a sketch there, constraining it to the 3D
model
> and -then- adding the dimension.
> But I consider
there must be a much more straight forward solution
to
this?
