Solved by ampster401. Go to Solution.
are your students using mice with a scroll wheel? After starting a sketch simply roll the scroll wheel in or out to zoom in or out.
I'm not aware of any settings which dictate what the zoom scale is set to when starting sketches. Over the yrs I've just gotten used to scrolling as needed.
We are running Windows on MacBooks. The mouse touchpads are very sensitive which is why the students are having difficulty controlling the zoom function.
I tried changing the initial view extents and this did not alter the axes dimensions upon opening a new file.
Maybe I'm missing something...what is a template file? I apologize but I do not have training using this software.
Paul,
That link you provided appears to describe how adjust the Initial View Extents which I believe only affects when you first open a file. I do not believe that works to setup how large of a drawing surface is provided when you start a sketch, or does it?
For the OP, that link doesn't include one vital step and that is you have to physically open the template file and then make the changes that link states.
For ref though to determine where your templates are, in Inventor click on Tools > Application Options > Files tab and take note of where your Default templates are located.
