Inventor Forum
260 Character Vault limitation
7 REPLIES 7
Message 1 of 8
939 Views, 7 Replies
Has anyone worked theirselfs into a position where folder names in the vault are too long, thereby making it so that you cannot manipulate files within Vault explorer. How do you shorten the folder name once the filename string exceeds 260 characters? I would think that we're not the first to encounter this problem. Using Inventor 11 SP2 and Vault 5.
Thank you,
Andrew Grove
7 REPLIES 7
Message 2 of 8
For faster response, you might try reposting in the Vault group.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
wrote in message news:5667370@discussion.autodesk.com...
Thank you,
Andrew Grove
Message 3 of 8
Windows max file name is 255 characters, folder names should follow the same
limits. Seen simular problems with Java which will support 260 character
file names. No know workaround for this problem as you are at the limits of
the OS.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 91.36
IV2008-pro sp1, SpacePilot Rel V: 3.4.2 Dvr V: 6.3.3
"Dennis Jeffrey" wrote in message
news:5667465@discussion.autodesk.com...
260-399-6615
Thank you,
Andrew Grove
Message 4 of 8
It appears that Vault is appending some character string to the filename. The error that we are encountring only happens when an attempt is made to manipulate data inside of Vault explorer (copy design, rename or move). When we use Word to count the character length of a file that is causing problems within vault, the filename length including folder path is less than 260 characters.
Thank you,
Andrew Grove
Message 5 of 8
As Dennis's post, the Vault user forum would best fit this topic.
XP-Pro, sp2
wrote in message news:5667851@discussion.autodesk.com...
Thank you,
Andrew Grove
Message 6 of 8
I got the same problem.
Is there a way to find where in vault the 260 caracters is exceeding?
I want to made a get latest version of an old project (3 years old).
I don't understand how it's work at the time we install the files in the vault & now nothing is working!
Message 7 of 8
RobJV
Yes.  The Vault uses the temp folder or at least used to.  When you perform renames, copy design, etc. it will append the characters from the temp folder so you might want to try shortening the temp folder location.  You might want to try this if you have not already:
Here is the process for changing the location of the temporary folders, let me know if you have any issues setting this up.
1. Create a folder at the root of the local drive and name it TEMP.
2. Click Start, right-click My Computer, and then click Properties.
3. In the System Properties dialog box, click the Advanced tab.
4. Click Environment Variables.
5. Repeat the following steps for both the TEMP and the TMP User variables: a.  In the User variables list, select the TEMP variable, and then click Edit.
b.  In the Variable value box, type %drive%\TEMP, and then click OK.
Note %drive% is the local drive where you created the folder in step 1.
c.  Repeat steps a and b for the TMP variable, if it exists.
6. Repeat the following steps for both the TEMP and the TMP System variables: a.  In the System variables list, select the TEMP variable, and then click Edit.
7. Click OK two times to close the System Properties dialog box.
Rob
Message 8 of 8
I use the Long Path Tool to overcome this problem. Should work for you too.
