Inventor Forum
2560x1440 Issue / Performance problem
5 REPLIES 5
1060 Views, 5 Replies
Inventor 2013 (from BDS Ultimate)
Windows 7 x64. SP1
8MB
GTX 560 2MB card, latest 327.23 drivers
I upgraded to an ASUS PB278Q monitor and set the resolution to 2560x1440.
--Inventor opens to Welcome screen, the toolbar "quivers", and Inventor closes after about 30 seconds.
--If I set resolution back to 1600x1200, Inventor runs.  If I then reset the resolution to 2560x1440 while Inventor is open, close it, and run Inventor again, it works....sort of.
I can deal with the above workaround, but here is the bigger problem (not sure if they are even related):
--Pan does not work--either the middle button, from the toolbar, or from the Viewcube menu
--Viewcube works sporadically--it does not highlight when passed over.  If I dbl-click on a side, that works.
--CPU is pegged, Inventor is quite sluggish.
--3DConnexion Space Navigator works fine.
--Inventor Fusion works fine.  Mouse buttons/pan work as they should.
--Drawing doesn't matter--same with new drawing or old.
--Compatibility mode, or any other mode, has no effect.
--Reinstalled Inventor, no effect.  All SP's, etc. applied.
--Checked to see what is happening with Process Monitor and found that there seems to be an endless loop of the following processes:
Date & Time: 10/17/2013 1:37:59 PM
Event Class: File System
Operation: CreateFile
Result: SUCCESS
Path: C:\Windows\Fonts\segoeui_5.ttf
TID: 20752
Duration: 0.0000369
Desired Access: Generic Read
Disposition: Open
Options: Synchronous IO Non-Alert, Random Access
Attributes: n/a
ShareMode: Read, Write, Delete
AllocationSize: n/a
OpenResult: Opened
Operation: QueryInformationVolume
Result: BUFFER OVERFLOW
TID: 20752
Duration: 0.0000036
VolumeCreationTime: 1/7/2012 12:34:14 PM
VolumeSerialNumber: BE57-1AF8
SupportsObjects: True
VolumeLabel: Pyrʹ
Operation: QueryAllInformationFile
TID: 20752
Duration: 0.0000042
CreationTime: 10/16/2013 12:06:57 PM
LastAccessTime: 10/16/2013 12:06:57 PM
LastWriteTime: 6/17/2012 8:31:30 AM
ChangeTime: 10/16/2013 12:06:57 PM
FileAttributes: A
AllocationSize: 761,856
EndOfFile: 758,808
NumberOfLinks: 1
DeletePending: False
Directory: False
IndexNumber: 0x29000000015241
EaSize: 0
Position: 0
Mode: Synchronous IO Non-Alert
AlignmentRequirement: Word
Operation: CreateFileMapping
Result: FILE LOCKED WITH ONLY READERS
TID: 20752
Duration: 0.0000019
SyncType: SyncTypeCreateSection
PageProtection:
Operation: QueryStandardInformationFile
Result: SUCCESS
TID: 20752
Duration: 0.0000025
EndOfFile: 758,808
NumberOfLinks: 1
Directory: False
Result: SUCCESS
TID: 20752
Duration: 0.0000009
SyncType: SyncTypeOther
Operation: CloseFile
Result: SUCCESS
TID: 27304
Duration: 0.0000199
I notice a similar pattern in Inventor Fusion, but it doesn't repeat endlessly as it does in Inventor.
I don't think it is the font--I switched to Arial and the path in the processes showed Arial.
Any ideas?
Scott
5 REPLIES 5
-niels-
From the Knowledge base:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=8324549&linkID=22152743&siteID=123112
Are you using a DVI connection or a HDMI cable?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
in reply to: -niels-
I'm using a DVI-D duallink cable.  When I first got the monitor, all I had was an HDMI cable which did limit the resolution to 1920x1200 (limitation of the GTX 560).
Could be wrong, but I don't think the shuddering toolbar/crash problem has anything to do with the endlessly looping processes/broken pan & viewcube/maxed out CPU problem.  If I drop back to a lower resolution, the problems are still there.
I've searched the groups and the closest I can find to this is dennishoegh's problem here:
http://forums.autodesk.com/t5/Inventor-General/Inventor-2013-extremley-slow-in-IDW-s/m-p/3591066#M44...
Doesn't look like this ever got resolved.
Ray_Feiler
If we refer to Wiki and Nvidia it doesn't seam to be hardware related.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-560ti/specifications
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Ray_Feiler
in reply to: Ray_Feiler
Oops, Nvidia GTX 560 spec's http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-560/specifications
I solved my problem.  It was so easy--all I had to do was reinstall Windows on a new drive, scrounge around for driver and BIOS updates, reinstall every program I have, and wait through countless hours of Windows updates and Service Packs (making sure to check Inventor after each to be sure it was ok).
And now it works.  Sometimes the nuclear option is the best.
