Inventor Forum
2015 - Tube and Pipe does not honor new size
4 REPLIES 4
karthur1
348 Views, 4 Replies
I created a pipe run using 1/2 tube.  I would now like to change this to 1/4.  When I do the tube size stays the same.
http://screencast.com/t/R8HHhtLhmxs
Can someone explain how to get this to change.  As you can see in the above video, I am selecting the "Change Size" in the context menu for the hose, but it has not effect.
4 REPLIES 4
blair
in reply to: karthur1
This is how I do it it T & P with flexible: https://screencast.autodesk.com/main/details/10076373-f181-4640-baaa-d0feb46400f4
Delta Tau Chi ΔΤΧ
karthur1
in reply to: blair
Blair,
So you have created a style for each different size tubing?  Are those styles stored in each assembly are are they published to a shared library?  Would you export one of those so I could see how the style is built?
Kirk
blair
All "Styles" used in T & P are stored in the Tube and Pipe Assembly IAM file. I can't attach files to this user forum at work, send me an e-mail at: blair dot stunder at arcticmfg dot com and I will send you my T & P IAM file to look at. In this case I modified an existing Parker file.
Delta Tau Chi ΔΤΧ
cbenner
in reply to: blair
Guys,... the tube & pipe "template" file is "Piping Runs.iam".  It is found in your Design Data path... wherever you have put that.  Save all T&P styles there to have them available for future use.  And yes, you should have one defined for each size of tube or pipe that you want to use.
