Inventor Forum
2015- Part "Ghosting" in assembly
17 REPLIES 17
Message 1 of 18
karthur1
1355 Views, 17 Replies
Sometimes when I place or move a component, it will leave a wireframe of the part behind.  If I zoom in or out it will go away, but then when I zoom back cloase to the level where the ghosting appeared, it is there again.  I can orbit and the ghost is still there.  The only way to get rid of it is to close/reopen the assembly.
 I am using 2015 RTM Update 1 and under the Tools>App options, hardware tab, I have the "Performance" setting checked.  I am also using the latest graphics driver for my setup.  Attached is the hardware diagnostics file.
I see this pretty often, but I can't reproduce it (it just happens). I know this was an issue during beta, just wondering if there has been any progress on preventing this from occuring.
Kirk
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 337.88)
INV Pro R2015, (update 1)
Vault Pro 2015
17 REPLIES 17
Message 2 of 18
in reply to: karthur1
I get this too, no fix as of right now but instead of exiting the assembly, just click on half section view then end section view. I moved the button to be on the main ribbon so i didnt have to change tabs everytime.
Message 3 of 18
bob_holland
Karthur1,
If you set your Inventor Graphics setting to conservative mode and software graphics, does it make a difference?
Application Options > Hardware Tab
Thank you.
Bob Holland
Autodesk Product Support
Message 4 of 18
karthur1
in reply to: bob_holland
Bob,
Seems like I have tried the Consertive setting, but the ghosting eventually returns even with that setting.
I will try it again next time I experience this.
Kirk
Message 5 of 18
I never had this problem in 2012 or 2013, both on the samne hardware and video card. I have just upgraded to 2014 (same hardware and video card) and now I see this quite often. My video card (ATI Firepro V7800) is not listed in the hardware compatibility list. I have tried using various flavours of the AMD driver files but with no success.
It's very sporadic and doesn't really cause me any problems. But I suspect it has something to do with incimpatibility.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 6 of 18
WHolzwarth
Here's an interesting sample.
Opened with 2013, the strings are looking good.
In 2014 and 2015, they are nearly invisible.
Walter
Walter Holzwarth
Message 7 of 18
karthur1
Bob,
Working this morning on an assembly.  Placed a part and then moved it, and the ghosting appeared.  My graphics was set to "Performance", so I changed it to Conservative.  When I did that, the ghosting went away.  I continued to work and then a while later, I moved a different part and the ghosting appeared again. This time, I checked the "Software Graphics" box.  When I did that the ghosting was removed.  Later, the ghosting reappeared on another part when I moved it.
The image below shows ghosting for a fastener that I placed in the assembly, but it happens on other parts as well (not just bolts).
Kirk
Message 8 of 18
bob_holland
Kirk,
I think that I would like you to roll your driver back and see if this one helps:
http://www.geforce.com/drivers/results/71704
Does this happen on all of your models or just a particular model?
Thank you.
Bob Holland
Message 9 of 18
karthur1
Bob,
Installing that driver now (332.21).
It comes up at random times so I cant say that it happens on "ALL" of my files.  I have seen it several times though.
Kirk
Message 10 of 18
mcgyvr
@Anonymous wrote:
Kirk,
Thank you.
Bob.. doesn't the fact that he had the same issue with "software graphics" on say its NOT related to his graphics card/driver version?
I "thought" software graphics does NOT use the graphics card at all.
Message 11 of 18
karthur1
Another instance of ghosting using the suggested driver.
Kirk
Message 12 of 18
bob_holland
Kirk,
Can you please send us a screen shot of the following dialog boxes:
Thank you.
Bob Holland
Message 13 of 18
karthur1
Message 14 of 18
lkrenzler
I get exactly the same thing with 2014 SP2.  I'm using a quadro K2000 with the 334.95 drivers.  I didn't used to get it until recently, I think with SP2.
Inventor Pro 2019 - Win. 10 - GeForce GTX 1080 .
Message 15 of 18
bob_holland
Kurt,
Please try the following and let me know if it makes a difference:
1. Go to Application Options->Display->Minimum frame rate, change the value from default to 0, and test again.
2. Turn off Display Silhouettes: Tools > App Options > Display > Settings
3. Try toggling the visual style from Shaded to Shaded with edges to something else.
4. Try to modify the Tools > App Options > Display > Display Quality > Form "Smoother" to "Smooth."
5. Make sure the DPI setting of Windows display is set to 100%.
Thank you.
Bob Holland
Message 16 of 18
cnewmanVIK
This problem has been talked about here
http://forums.autodesk.com/t5/Inventor-General/Graphics-Issues-in-Inventor-2014/m-p/4987466#M506166
since Oct 2013.  Seems to be something with the shaded with edges setting.
Message 17 of 18
karthur1
Bob,
I did all the items listed and that doesnt work either.  If I use shaded with edges, wireframe, watercolor or illustration visual style it ghost is visible.  Any of the other visual styles will cause it will go away temporarily.  As I continue to work, it will eventually return.
Kirk
Message 18 of 18
ball
Is there any fix for this issue yet? I've tried all of the suggested options with no luck.
