I need to use the move face command. I can find it in the search tool, but I cant find it on the ribbon. You would think that it would be on in the "Surface" panel, but its not. Can someone point me to it?
Kirk
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I think like niels.
There is nomore edit solid body enviroment...and the move face command is an obsolete remnant replaced by Direct command, i presume.
Admaiora
I looked everywhere for it. Wonder why the search does not "direct" me to the "direct" tool.
Thanks, that works for me.
For good measure, i think the official name is "direct edit".
The icon only displays "direct", but it says "direct edit" in the flyout.
Niels van der Veer
The Netherlands
3D model tab, Modify panel, Direct [Edit].
Andy
