Howdy all,
When placing a new 'base' view in a drawing (obviously), if you drag your mouse around to place the object my 'solid' (even if solid is not on) is very fuzzy until you place it. Once places it looks good in wirefram and solid. The same for all view types/angle. This doesnt affect anything else so far as I can see, just a cosmetic blurr while placing.
Worth mentioning? Questionable. Was it there in 2014? No, such as I think it might be worth the mention.
Anyone else seeing this?
tks
At this time there have not been similar reports of what you claim here with 2015 release. I just wanted to offer the site below to where you can compare your installed video card driver versus the one we have certified.
You can find your driver info a few places.
Start>All Programs>Accessories>System Tools>System Information. Expand components and highlight display to loist driver info. Compare it against the link below.
Don
I have seen the same thing along with ghosting but it might be due to the parts being created in 2014
...And Some iIPN's have to be edited in IDW's because the colors are not updating. I have to change it from shaded to non shaded, close the dialog box and then reopen it and put it back to shaded.
Don,
To make point to my 'claim' as you put it, here is a screen shot. Looks fuzzy to me.
Is my video card on that list? No, but that list also doesnt show 2015 Autodesk packages. And in 2014 with my Nvide GTX 760 video card, I did not see this issue.
Did you try changing the options in tools..document settings..drawing tab..?
Specifically set use bitmap to "offline only" and then adjust the bitmap resolution.
