Inventor General Discussion
Mark_Wigan
Message 1 of 20 (2,445 Views)
2014 - default inventor Macro or API command button will not work in 2014
2445 Views, 19 Replies
04-24-2013 04:17 AM
ok, i installed 2014 yesterday, and using all default configurations the 2 buttons (Macro or VBA Editor as per snapshot attached) will not do anything at all.
reboot inventor and workstation no change.
so i then...
did a repair no change.
did a reinstall, no change.
install SDK user tools and Developer tools no change, uninstall same, no change.
multiple reboots of inventor and workstation, no change.
unloaded many standard inventor add-ins (as per default installation) , no change.
pointed default vba project to custom location, no change.
i have never seen this problem with any version of inventor to date.
anyone else seeing this?
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
It's a known bug in the Beta version, but it seem it's always here in the RTM.
In order to fix this, in your Inventor installation files, go to 3rdParty\x64\VBA\Vba71033.MSI (or x86 for the 32b version) and install the MSI regarding the language of Inventor (1036=French, 1033 = English, etc.).
This will fix the VBA.
mrattray
Message 2 of 20 (2,428 Views)
Re: 2014 - default inventor Macro or API command button will not work in 2014
04-24-2013 04:56 AM in reply to: Mark_Wigan
What happens if you press Alt+F11?
Mike (not Matt) Rattray
Mark_Wigan
Message 3 of 20 (2,425 Views)
04-24-2013 05:02 AM in reply to: mrattray
hi Mike,
nothing at all with that either, which was actually my usual approach, when the keyboard did not work i tried the buttons.
best regards,
- Mark
mrattray
Message 4 of 20 (2,417 Views)
04-24-2013 05:16 AM in reply to: Mark_Wigan
Try changing your default project file to this one and restart Inventor.
xdumont
Message 5 of 20 (2,380 Views)
04-24-2013 08:04 AM in reply to: Mark_Wigan
Board Manager
ChrisMitchell01
Message 6 of 20 (2,362 Views)
04-24-2013 03:01 PM in reply to: xdumont
Mark,
Can you please confirm the exact OS version & locale you are running ? Also which installer did you use to install Inventor ? PrDS, FDs, other suite, or "just" Inventor.
Chris
Chris Mitchell
Inventor Customer Engagement Team
Mark_Wigan
Message 7 of 20 (2,345 Views)
04-24-2013 06:33 PM in reply to: xdumont
thanks xdumont that fixed it. !!!
quote:"In order to fix this, in your Inventor installation files, go to 3rdParty\x64\VBA\Vba71033.MSI (or x86 for the 32b version) and install the MSI regarding the language of Inventor (1036=French, 1033 = English, etc.).: "
unquote.
Chris, just to answer your questions on this, and note that before i read the updated responses this morning, i actually had uninstalled inventor last night and installed it this morning, using all the usual precautions. still no change to the problem.
OS is win7 64bit SP1 (but this specific pc is running home premium). i will let you know if i have the same issue on my other workstations which are win7 64bit ultimate.
i installed off the usb stick that autodesk shipped to me for my English version of PDSU. And, at time of installation, i chose all the offered suite applications to be installed except vault, alias and mudbox.
i made sure not to change any application options especially default vba project, before testing the buttons or ALt+F11. the only thing that ended up working was the language pack manual install as noted above!
thanks again for everyones responses, i am back to work again.
best regards,
- Mark
Board Manager
ChrisMitchell01
Message 8 of 20 (2,339 Views)
04-24-2013 06:53 PM in reply to: Mark_Wigan
Thanks Mark,
If you look at Control Panel, Region and Language, what do you have set for Format & Location ?
-Chris
Chris Mitchell
Mark_Wigan
Message 9 of 20 (2,330 Views)
04-24-2013 07:58 PM in reply to: Mark_Wigan
hi Chris, mine are set to English Australia as per snapshot.
best regards,
- Mark
Mark_Wigan
Message 10 of 20 (2,327 Views)
04-24-2013 08:12 PM in reply to: mrattray
hi Mike, sorry i did not reply earlier this morning...
that blank .ivb file did not help.
by the way it may be interesting for future reference, that after i reinstalled inventor last night and this morning i took note that the default location for VBA project is different to what i have been aware of in earlier versions.
see snapshot showing new path... at least on win7 OS
best regards,
- Mark
