This dialog has been around for as long as I can remember.
Could we get this added to the prompts, please so that I can suppress it FOREVER? It is a real PITA having to click the OK everytime I want to migrate a part/idw/iam.
I know if I migrate with the TS, I would not have to do that.
You can always use the Save All option too, then you only have to accept this prompt once to migrate all open files..
You know that if they put that in there it would only "stick" for the current session. Then everyone's going to have to deal with more of my borderline belligerent "quit breaking stuff" posts.
I entered this as a wish in our database
1465121 Allow user to turn off the "Data Format has changed" dialog
Bob
Defect 1465121 is still open in our defect database. I have not seen a lot of activity around it.
Bob
I would love for this to be fixed. This is one of the things I hate about Inventor. I love the software mostly but this dialog is a total waste of time for me. and it gets really annoying when you know that the files in the vault have already been migrated. I can see it being useful for those who do not know it will limit them to what version of the software will open the file. But for a subscription user all our engineering staff know our files have been migrated and we all use the same version so this dialog does nothing but slow our engineers down and make them less productive. Ok so it might be of little importance to the people who have bigger fish to fry, I'm one that would really like to see an option to shut of the dialog.
I don't understand how you would see this dialog if all the parts have been migrated PRIOR to opening them in Inventor?
Here is another tip.
You could use following iLogic code and place it in an external rule in your template files of an older Inventor version and trigger the rule automatically "After Document Open".
When opening an old version file that you have prepared (as I just explained above) in a new version of Inventor, the file will be automatically migrated and saved with the new version without showing any dialog.
You can also run the rule at any time in the new Inventor version to migrate and save a file without getting a dialog.
Sub Main() If ThisApplication.ActiveDocument.NeedsMigrating = True Call execute_command("AppFileMigrateCmd") ThisDoc.Save End If End Sub Private Sub execute_command(cmd As String) Dim oCtrlDef As ControlDefinition oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item(cmd) oCtrlDef.Execute End Sub
Bob
Hi everyone,
I just saw where there was an update on a related thread and wanted to tie these two topics together for future users who find this thread in a search:
In short, the issue seems to be that the Vault migration process migrates the vault database files, but it does not migrate the actual Inventor files as we might assume.
Some related links:
Data management and Migration:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-ACBC3CC9-D3C2-4CDA-8A98-C734435DE1E9
Migrate Inventor files in the Vault:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-F223DE14-5278-4D8F-A7DF-68EAFE839B2E
More than you ever wanted to know about Autodesk Inventor Data Migration:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FB9B4422-2348-46FA-964B-7845D9D96018
I hope this helps.
Curtis
