Inventor General Discussion
Member
arnie.martin
Message 1 of 3 (1,513 Views)
2013 Texture Mapping/Rendering Issue
1513 Views, 2 Replies
11-13-2012 11:04 AM
I think this is a known issue and I have scoured the boards looking for a solution but I have not found one, so here goes: This applies to Inventor 2013 appearances, visual styles, and rednering options.
When I create a custom Appearance and assign an image map to the appearance several problematic things happen depending on which visual style is active. For example if I create a plywood material with an appropriate texture map and view it in shaded style the texture breaks in the middle of a square surface with an undesireable tiling effect. This is easily solved by switching to realistic style and either moving the texture map an appropriate distance in the style editor or using the new texture manipulator tool to do the same. This is detailed in this post: http://forums.autodesk.com/t5/Autodesk-Inventor/Textur-Manipulators-XY-Manipulation/m-p/3531094/high..., and achieves the desired effect but ONLY when viewed in realistic mode.
The real problem begins when I want to render using inventor studio. Apparently inventor studio defaults to shaded mode instead of realistic mode and ignores any and all texture manipulation when rendering an image, in fact in the render options "realistic" is not an option, only shaded and illustration. The three attachments illustrate the problem. Realistic shows the desired effect, shaded shows the lack of control in the default shaded visual style, and rendered shows the rendering engine's preference for the problems of the shaded mode as opposed to the more desireable realistic mode. Am I missing something here? Is there a setting that will allow me to force the rendering engine to use the texture transforms from the realistic visual style when making a rendering?
I have several possible solutions to this, none of which I like. First is to use decals in the parts which give a lot more control on large surfaces like the square of my panel. But decals seem to ignore the other advantages of appearance styles like reflectivity etc. The second is to ray trace a realistic image in the normal viewport (not using stuio) and export it to a tff file or some other uncompressed format but this lacks the extra control that studio gives you when rendering an image such as lighting and scene styles, camera controls, etc and it is limited to your viewport resolution. Has anyone had a similar issue or found a better solution? It seems to me that the rendering engine isn't up to par with the more robust features of the visual styles, and apperances. With the introduction of "Showcase" in the product design suite it appears autodesk is pushing realistic rendering into another (and also expensive) piece of software, but c'mon shouldn't inventor be able to render parts and assemblies with even basic control over texture maps? Any insight would be helpful.
Arnie
Valued Mentor
mpatchus
Message 2 of 3 (1,505 Views)
Re: 2013 Texture Mapping/Rendering Issue
11-13-2012 11:23 AM in reply to: arnie.martin
There are a couple of decent tiiling programs out there that can generate nearly seamless images for use as materials in Inventor.
I've had pretty good success with Wood Workshop which is put out by Sprial Graphics.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Member
arnie.martin
Message 3 of 3 (1,495 Views)
11-13-2012 12:01 PM in reply to: mpatchus
Wow, nice rendering, and I will look into the software you mentioned, but it still seems as though there should be a way to position higher res texture maps on part faces without using decals or seamless textures. The functionality is there with all of the position options avilable in the appearance editor but they only apply in one visual style and not in a rendered image. Very frustrating.
