Inventor Forum
2013 Task Scheduler log file
6 REPLIES 6
karthur1
338 Views, 6 Replies
When I am in the Autodesk 2013 Task Scheduler and I click on the log file path to view the log file..... I get the log file, but it also opens the "View Downloads" window.. which I dont want.
It just started this in 2013 and it does it on every computer that I have tried it on.
Is there a way to make it not open the "View Downloads" when I view the log file?
6 REPLIES 6
in reply to: karthur1
Does the same here, I can't find a way to disable it.
karthur1
"New" feature I guess.  One of the new things I dont like about 2013.
The other thing I don't like about migrating files is if there are ILogic rules that pop up a confirmation dialog, the boxes pop up under the task scheduler, and it will not continue until you confirm.  Seems there should be a way around this but I haven't been able to find it.
karthur1
@Anonymous wrote:
The other thing I don't like about migrating files is if there are ILogic rules that pop up a confirmation dialog, the boxes pop up under the task scheduler, and it will not continue until you confirm..
Ditto.....  Makes it useless while letting this run overnight unattended.
bobvdd
If you are unhappy with the way Inventor 2013 accesses log files, why don't you try the log tool that I wrote about on the support blog.
Bob
Bob Van der Donck
Principal UX designer DMG group
bobvdd
in reply to: bobvdd
On the second issue that was brought up in this conversation, I agree that the current Task Scheduler behavior defeats the purpose of doing a migration in batch 😞
I have logged following defect :
1469545 Task scheduler does not disable iLogic rules that are triggered during open or save
Thanks.
Bob
Bob Van der Donck
