I have a model with vibrators and weights that need to align with the center of gravity. I have positional reps for changing the vibrator angle. then I use weights to move my cg. I tried using a level of detail to suppress the weights im not using. shouldnt this change the center of gravity? Mine isnt changing in 2013, has this been the case for the last versions? Or does suppressing in a level of detail not totally remove the part from the physical properties?
thanks for the reply,
this doesnt make any sense. if the part is suppressed he physical properties shouldnt include it.
I guess I will have to do it the hard way.
Here's what Help has to say on COG:
Design View representations and Level of detail representations do not affect center of gravity. The center of gravity only refers to the Master level of detail representation of the assembly. The suppression or substitution of the model does not affect the location of the center of gravity.
I hope that clarifies what's supposed to happen.
This is odd behavior considering that an assemblies mass does take LOD settings into account.
Does anybody know of a way to change a part's chenter of gravity without having to manualy add weights or change the part's density/mass?
If the density/mass is correct and the model is correct then the center of gravity should be correct.
If its not then either the part is not modeled correctly or the material properties are incorrect.
I am aware of the incorrect mass and geometry. That is what makes the center of gravity. im just asking if theres a way to change the COG without having to model the internals correctly. A "shortcut"
I don't know because I'm not lazy and don't do "shortcuts". 🙂
I wouldn't think so..
If you need a proper COG then you need the proper model and the proper material props.
Ive not tried this.
Try changing the weights you dont want in the assembly's BOM to referance, this works in the mass calculations.
