Solved by dave.anderson. Go to Solution.
The Perforated Plate material that existed in pre-2013 Inventor is included in the Autodesk Appearance Library, so you'll need to copy Plate - Perforated OR Plate - Perforated1 to the Inventor Material Library or activate the Appearance Library and assign it from there.
