Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
2013 Material physical properties - units
4 REPLIES 4
djreesing
3223 Views, 4 Replies
Hi there,
I've just noticed that when I view/edit the physical properties of a material, the units are not in metric/iso format. I'm certain that a couple of months ago when I added some materials to the library, they were in metric/iso format. Is this a setting somewhere? or has this changed since SP1.1?
Can someone confirm this, or am I the only one who has this issue?
Best regards,
Daniƫl Reesing
Inventor 2013 Pro SP1.1
4 REPLIES 4
SBix26
in reply to: djreesing
In the lower left corner of the Material browser you will find this menu:
djreesing
Found the solution myself already. At the bottom left corner of the material browser there is an option 'Set Display Units' (see image below).
djreesing
in reply to: SBix26
You were just a second ahead of me Smiley Wink
One thing to remember when changing the Display Units, is that it applies that change to the entire library and not just that material.  This may or may not be an issue for you.  Just a heads up!
