Inventor General Discussion
Brendabr12345
Message 1 of 18 (1,808 Views)
2013 Graphics Issues
1808 Views, 17 Replies
11-02-2012 11:56 AM
I have one PC in our office with some graphics issues.  In a new IDW when the user adds a dimension, then zooms out, all the views disappear except for the active view.  The file were using is one part and two views on the IDW so it's not a large assembly or anything complicated.  I've installed the latest driver from NVIDIA and changed the Inventor hardware settings from Performance to Compatability and back and forth which helps temporarily but then it goes back to the same issue after a while. I've maximize RAM utilzation and the problem isn't being seen in any other applications and we have the latest service pack 1.1 installed. Any suggestions?? Am I missing something?
The configuration is:
Dell Precision 3500
Win 7, 64
12g RAM
Quad core
Nvidia Quadro 2000
Thanks!
See if Windows "Aero" is enabled on this machine. A post a short while back with a graphics problem fixed it by enabling "Aero".
Valued Mentor
japike
Message 2 of 18 (1,802 Views)
Re: 2013 Graphics Issues
11-02-2012 12:02 PM in reply to: Brendabr12345
Is it just the one drawing that has this issue?
Have you tried the drawing on another PC?
Can you post the part and drawing?
Peace,
Jeff
Inventor 2013
pball
Message 3 of 18 (1,798 Views)
11-02-2012 12:07 PM in reply to: japike
Myself and coworker have actually had an issue like this. Sometimes when dimensioning all the views would disappear and if we would zoom in or out the views would reappear. This has happened on more than a few drawings, though I couldn't locate any off the top of head or upload them due to confidentiality.
Brendabr12345
Message 4 of 18 (1,784 Views)
11-02-2012 12:44 PM in reply to: japike
This is happening on multiple files on the same PC, files function fine on other PC's.
mcgyvr
Message 5 of 18 (1,771 Views)
11-02-2012 01:20 PM in reply to: Brendabr12345
update the graphics card driver.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Brendabr12345
Message 6 of 18 (1,760 Views)
11-02-2012 01:42 PM in reply to: mcgyvr
I've actually upgraded the video card driver straight from the NVIDIA site with temporary improvement.  I'm wondering if there is a setting under the NVIDIA control that I need to modify specifically for Inventor.  The issue appears to occur on one of the dual monitors that has the digital connection.  Perhaps these issues are related, but when I move Inventor to this monitor, then close and re-open Inventor it automatically opens on the base monitor.  Could this be an indication of something related?
blair
Message 7 of 18 (1,739 Views)
11-02-2012 08:26 PM in reply to: Brendabr12345
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Delta Tau Chi ΔΤΧ
Active Member
ryangerstner4819
Message 8 of 18 (1,564 Views)
12-14-2012 06:24 AM in reply to: blair
Me and my employees are having the same issue as Brendabr12345. We just upgraded to Inventor 2013, installed SP1.1, & updated our graphics card drivers. I verified we are running a theme with "Aero". And when I uncheck "Enable transparency", the disappearing act occurs with half the frequency. I attached the drawing. Here is our setup:
Dell T3500
Windows 7 Pro
NVidia Quadro 2000
6 GB RAM
Any other ideas?
Best regards,
Ryan
blair
Message 9 of 18 (1,548 Views)
12-14-2012 08:35 AM in reply to: Brendabr12345
The IDW without the related files is useless. A screen capture would probably suffice to show the problem.
Win7-64
Delta Tau Chi ΔΤΧ
Active Member
ryangerstner4819
Message 10 of 18 (1,503 Views)
12-17-2012 04:27 AM in reply to: Brendabr12345
I found a strange fix. I changed my hardware settings in Application Options > Hardware, from performance to quality. I closed the idw, and reopened it. I was having the same issue, so I switched the hardware setting back to performance, closed the idw, then reopened the file. I worked in idw environments for 30 minutes with no issues, then deployed to my employees. Last I asked on Friday, everything was running fine.
