Working in an assembly with sub-assemblies. I am trying to move a part not much more than the diameter or a hair, but this is causing lots of problems.
I am forced into editting an assy constraint. So I go thru the menu and except the edit.
Constraint box opens / and iventor says "ready" but it will not let me select and surfaces to define the mating.
My question is What is it the constraint is ready for?
Is this normal behavior?
Is this inventors way of telling me to delete the constraint and start all over?
thx
Solved by not2013. Go to Solution.
I was able to get the desired results by editting a different constraint. May take another look at the constraint tutorial.
