Inventor General Discussion
*Pro
Dennis_Jeffrey
Message 11 of 45 (895 Views)
Re: 2012 Select Other Tool
06-30-2011 07:16 PM in reply to: scottmoyse
Sh..................   It's "New and Improved"........   can't you tell?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Distinguished Contributor
beau-tech
Message 12 of 45 (868 Views)
07-03-2011 09:56 AM in reply to: beau-tech
Me again. Please hotfix the select tool & 3d constraint issue asap (see my previous post). This is getting old, fast. I am making extra workplanes so I just constrain stuff. Should have waited for sp1.
scottmoyse
Message 13 of 45 (863 Views)
07-03-2011 12:53 PM in reply to: beau-tech
for hot fix requests you should contact your reseller and support, then together with your reseller fill out a business case form to get the fix considered by Autodesk
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
New Member
bogdansoare3455
Message 14 of 45 (800 Views)
07-08-2011 03:15 AM in reply to: beau-tech
beau-tech wrote:
Just installed 2012 and am still getting used to the new select tool. When 3d constraining and selecting the second constraint I get a confirmation tone but the 'ok' or 'apply' buttons are not available. If possible I can orbit around and pick the same feature, not requiring the select tool, and the constraint works. This is a fresh install on a rebuilt hard drive.
If I am not the only one, hope that this gets fixed. Very time consuming.
Pete Beau
IV 2012 pro
win 7
I have the same annoying problem. even more: if i use amber icon color theme instead of cobalt icon color theme (which is the default inventor theme) the select other tool doesn't appear at all.
I hope that this will be fixed asap
IV 2012 pro
win xp 32 bit
Valued Contributor
ACEDeSmedt
Message 15 of 45 (737 Views)
08-05-2011 04:49 AM in reply to: beau-tech
You are not the only one having trouble selecting the second (or third) select-set using select other
try constraining cylinders, downloaded from Festo. The inner cylinder surface plane is impossible to constrain
hope this will be fixed soon!
If this is the solution, push the solution button :smileywink: (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
Windows 7 (64bit) 12 Gb RAM - 2x Intel Xeon E5430
dacton
Message 16 of 45 (722 Views)
08-05-2011 07:48 AM in reply to: randym1982
Select other tool is a pain, but mine issue also includes that even if I scroll or pull down and select the "other" object, even though it highlights, it may not select the other object.  I find myself needing to sometimes change the view slightly (orbit or similar) and starting the select other over again.  Like Inventor knows its there, but the database is not refreshed for the select other.  weird.
Vlad.Makarov
Message 17 of 45 (702 Views)
08-05-2011 11:17 AM in reply to: mcgyvr
mcgyvr wrote:
A while ago I posted some "Autodesk Mottos" that I can't find now but
1 was "2 mouse clicks must be better than 1"
and "If it ain't broke, lets change it"
You hit the mark on this!
______________
Inventor Pro 2012
Vault Pro 2012
blair
Message 18 of 45 (680 Views)
08-05-2011 02:29 PM in reply to: Vlad.Makarov
I have posted on this as well, Autodesk says there is a fix in the works...I keep checking each day.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
feame
Message 19 of 45 (624 Views)
08-15-2011 05:16 PM in reply to: randym1982
Any update hotfixes yet?
The thing is riddled with other problems aside from the obvious, for example you can't constrain one part to another if the second part is a 'select other' face. It selects the face, and a part preview is shown, but the 'apply' button is unavailable so you have to cancel it which undoes the constarint.
scottmoyse
Message 20 of 45 (618 Views)
08-15-2011 05:48 PM in reply to: feame
Service Pack 1 isn't too far away.
Cheers
Scott Moyse
