Inventor Forum
2012 Select Other Tool
44 REPLIES 44
Message 1 of 45
1780 Views, 44 Replies
Hey Guys,
Am I alone in HATING the new select other behavior?  I used to be able to scroll till what I wanted was highlighted and then left click to select.  Now I have to move the mouse over and hit the green checkmark.  Here's a suggestion.  It's a simple fix.  Put the green checkmark on the left and the drop down on the right.  Don't make me hit another target.  I am getting used to the new marking menu.  The only issue I am having is sometimes it seems that I have to left click and then right click a part to get the correct context sensitive marking menu to pop.  On my machine it also pops a little slow but that is probably a graphics card deficiency.  The marking menu seems to be pulled from the Crysis Nano Suit function selector (for any gamers out there)  I love it there and I am sure I will remember all the different menus here soon.
Randy Martens
44 REPLIES 44
Message 2 of 45
mcgyvr
You are not alone.. And I haven't even loaded 2012. 🙂
A while ago I posted some "Autodesk Mottos" that I can't find now but
1 was "2 mouse clicks must be better than 1"
and "If it ain't broke, lets change it"
Message 3 of 45
in reply to: mcgyvr
Ha.  No kidding!
Message 4 of 45
scottmoyse
in reply to: mcgyvr
To be fair the original select other was rubbish in the sketch environment. Unfortunately they didn't even improve that with this version. So its worse for that reason alone. Why change something if you're not going ot make it better?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 5 of 45
in reply to: scottmoyse
Are there any updates at all on this? Can it be reverted back to how the other releases was which actually worked?
Example: try and create a new sketch plane on and object behind another and offset it. With the previous versions it was highlight the area, scroll to face, click and drag and move the plane to where you want it.
Now though, it seems you can only create a new offset workplane if there is nothing in front of it, PITA when working on assemblies. Even if you move the dialogue box over the object, the mouse button has to be released for it to select the object, by which point you can drag it now.
Just for the heck of saying it, can I just put out there I think inventor 2011 was near bang on perfect and it was the first release I've used since 6 that was stable, reliable, and useful. In the time I've been using the new release I'm finding it slow, buggy and unstable.
And when will the parts list / assembly tree be put on a pop up dashboard like everything else already?
Message 6 of 45
KevinLi-Autodesk
You can set back to classic context menu by clicking Customize button, switch to Marking Menu tab, turn on check box "Use Classic Context Menu", hit OK.
Kevin Li
SQA Engineer, Autodesk, Inc.
Hongyuan.Li@autodesk.com
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 7 of 45
in reply to: KevinLi-Autodesk
That reverts the context menu back, but doesn't alter the 'select other' tool.
Message 8 of 45
beau-tech
Just installed 2012 and am still getting used to the new select tool. When 3d constraining and selecting the second constraint I get a confirmation tone but the 'ok' or 'apply' buttons are not available. If possible I can orbit around and pick the same feature, not requiring the select tool, and the constraint works. This is a fresh install on a rebuilt hard drive.
If I am not the only one, hope that this gets fixed. Very time consuming.
Pete Beau
IV 2012 pro
win 7
Message 9 of 45
scottmoyse
That was a well thought out response from Autodesk! ;o) sorry couldn't resist posting that
Scott Moyse
Message 10 of 45
in reply to: beau-tech
I prefer the old as well.    If it "ain't" broke, then don't screw with it.
Message 11 of 45
Sh..................   It's "New and Improved"........   can't you tell?
Message 12 of 45
beau-tech
Me again. Please hotfix the select tool & 3d constraint issue asap (see my previous post). This is getting old, fast. I am making extra workplanes so I just constrain stuff. Should have waited for sp1.
Message 13 of 45
scottmoyse
for hot fix requests you should contact your reseller and support, then together with your reseller fill out a business case form to get the fix considered by Autodesk
Scott Moyse
Message 14 of 45
Pete Beau
IV 2012 pro
win 7
I have the same annoying problem. even more: if i use amber icon color theme instead of cobalt icon color theme (which is the default inventor theme) the select other tool doesn't appear at all.
I hope that this will be fixed asap
IV 2012 pro
win xp 32 bit
Message 15 of 45
ACEDeSmedt
You are not the only one having trouble selecting the second (or third) select-set using select other
try constraining cylinders, downloaded from Festo. The inner cylinder surface plane is impossible to constrain
hope this will be fixed soon!
If this is the solution, push the solution button 😉 (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
Message 16 of 45
Select other tool is a pain, but mine issue also includes that even if I scroll or pull down and select the "other" object, even though it highlights, it may not select the other object.  I find myself needing to sometimes change the view slightly (orbit or similar) and starting the select other over again.  Like Inventor knows its there, but the database is not refreshed for the select other.  weird.
Message 17 of 45
in reply to: mcgyvr
You hit the mark on this!
Message 18 of 45
blair
I have posted on this as well, Autodesk says there is a fix in the works...I keep checking each day.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 19 of 45
Any update hotfixes yet?
The thing is riddled with other problems aside from the obvious, for example you can't constrain one part to another if the second part is a 'select other' face. It selects the face, and a part preview is shown, but the 'apply' button is unavailable so you have to cancel it which undoes the constarint.
Message 20 of 45
scottmoyse
Service Pack 1 isn't too far away.
Scott Moyse
