I've got a case logged with Autodesk support for this exact issue. Will post their findings once I hear back from them.
Can you send a screenshot of how your right click menu looks when you have selected a face or edge.
Also try changing disabling the new marking menu and use "classic context menu" as in attached screenshot.
Right click on ribbon -> Customize user commands -> Marking menu(tab) -> "use classic context menu"
add my name to the list... Restarting Inventor makes it come back.
I'm having the same problem. I just installed Inventor 2012 with SP1 and my Select Other menu list also doesn't show up. I made the change to classic context menu as you suggested but that didn't change anything with the select other function. It is very difficult to use Inventor without a select other function. Any other suggestions would be greatly appreciated.
@Anonymous wrote:
Wow... no solution... as usual...
Do you have update 4 installed?
