Inventor Forum
2012 select other menu doesn't pop up
6 REPLIES 6
1032 Views, 6 Replies
We just installed 2012 and the new 'select other' pop-up window worked for about 2 days and just quit. Is it controlled by a setting I somewhere inadvertently changed?
Tags (1)
6 REPLIES 6
I've got a case logged with Autodesk support for this exact issue. Will post their findings once I hear back from them.
Rajesh.Sivaswamy
Can you send a screenshot of how your right click menu looks when you have selected a face or edge.
Also try changing disabling the new marking menu and use "classic context menu" as in attached screenshot.
Right click on ribbon -> Customize user commands -> Marking menu(tab) -> "use classic context menu"
Rajesh Sivaswamy
Support Specialist
Product Support
mcgyvr
in reply to: Rajesh.Sivaswamy
add my name to the list... Restarting Inventor makes it come back.
I'm having the same problem.  I just installed Inventor 2012 with SP1 and my Select Other menu list also doesn't show up.  I made the change to classic context menu as you suggested but that didn't change anything with the select other function.  It is very difficult to use Inventor without a select other function.  Any other suggestions would be greatly appreciated.
Wow... no solution... as usual...
mcgyvr
Do you have update 4 installed?
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-4-for-inventor-2012-sp2.html?v=2012
