Inventor Forum
2012 Make Components glitch
25 REPLIES 25
Message 1 of 26
ToddHarris7556
1307 Views, 25 Replies
Anyone else run into this?
Multi-body parts, using Make Components.
1) When you click the Browse folder icon to pick an Assembly to insert into, the 'Component Properties' dialog pops up, asking if you want to create a new assembly.
2) Whether you answer yes or no, no Browse Dialog pops up.
3) The path is left at the default of your workspace path. You can manually type in the path and Assembly name if you know it, but no ability to browse to it. It wants to create the new assembly in the default workspace folder.
Just checking sanity... someone else please say you've run into it. Thanks 🙂
Win7 / 64 Ult
IV 2012 Pro
PS - Also happens when you choose Make Part instead of Make components.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
25 REPLIES 25
Message 21 of 26
Mark Same problem here. I need a hot fix ASAP
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Message 22 of 26
Good Morning
Did anyone get a hotfix for this problem
We have just moved to 2012 and all the users have this issue which is proving a massive problem
Thanks in anticipation
Graeme
Message 23 of 26
Sorry, I have not seen a thing from Autodesk. I keep sending in reports and they keep asking me the same responce. It must be computer generated.
I am getting a new computer later today with a fresh install of everything. See if that helps me.
But for you all you can do is make your componets without making a new assembly and then install all your parts into an assembly in under Productivity use the Place at Component Origin and then ground all parts.
Douglas DuPont
Quadro M4000
Windows 10 64 Bit
Message 24 of 26
anyone had this issue fixed?
Strangely it doesnt happen at start of seesion but part way through the day
Regards
G
Message 25 of 26
I wish I could say that it was 'fixed', but unfortunately, all I can say is 'it seems to have resolved itself, and I have no idea how or why'.
Todd
Message 26 of 26
I don't have any news ether. I did build a new computer from and loaded all software fresh and seems to fix my problem also. My video problem cleared up also. Now I can work at 110 percent again. Wish I was on vacation still.
Douglas DuPont
Quadro M4000
Windows 10 64 Bit
