Inventor General Discussion
Valued Contributor
1 Kudo
Post 1 of 26
Accepted Solution
2012 Frame Generator - G_L Parameter won't update
1682 Views, 25 Replies
03-25-2011 02:58 PM
There seems to be a bug with the frame generator in 2012. When using the frame generator, the G_L parameter in each part should always update based on the line that it is attached to from the skeleton. Well in 2012, the frame member's length will update (the B_L parameter updates), but the G_L parameter will no longer update, it stays at its original value from when it was first placed.
Has anyone else had this problem?
I've attached the file as an example. The Height of the skeleton was originally 121.370 in, and now it is 82 in. The parameter for the outside vertical legs will not update from 121.370 in to 82 in. I've tested this a few times with the same results.
IMAGINiT Technologies
www.IMAGINiT.com
The Inventor 2012 Hotfix for this issue is now available from the Data & Downloads site:
 http://usa.autodesk.com/getdoc/id=DL17089522
Best regards,
Alessandro
To clean-up existing 2012 frame generator assemblies that were created before the hotfix was applied, use the VBA macro as documented on our support blog.
Bob
*Expert Elite*
391 Kudos
Post 2 of 26
Re: 2012 Frame Generator - G_L Parameter won't update
03-25-2011 06:04 PM in reply to: Justin.Williams
how have you got 2012? I can only assume its the beta copy and you are posting here cos the beta has ended? which doesn't make much sense because you are likely to get some help from the beta site than here.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
*Pro
40 Kudos
Post 3 of 26
03-25-2011 07:30 PM in reply to: scottmoyse
Inventor 2012 is available for download to subscription customers. I downloaded mine Tuesday.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Valued Contributor
1 Kudo
Post 4 of 26
03-25-2011 07:44 PM in reply to: Justin.Williams
Yeah I work for a reseller but just finally got a chance to install and mess around with the non-beta today.
www.IMAGINiT.com
*Pro
40 Kudos
Post 5 of 26
03-25-2011 07:59 PM in reply to: Justin.Williams
I can confirm this on a new FG Assembly. I started with a height of 122, created the components, saved, exited and reopened. B_L changes, but G_L does not.
Valued Contributor
1 Kudo
Post 6 of 26
03-25-2011 08:05 PM in reply to: Dennis_Jeffrey
Thanks Dennis. I will be creating a ticket with Autodesk for this one - I will post again when I hear something back.
www.IMAGINiT.com
*Pro
40 Kudos
Post 7 of 26
03-25-2011 08:07 PM in reply to: Justin.Williams
I'll do the same...
*Expert Elite*
391 Kudos
Post 8 of 26
03-25-2011 08:25 PM in reply to: Dennis_Jeffrey
its not on my sub page
Cheers
Scott Moyse
*Expert Elite*
391 Kudos
Post 9 of 26
03-25-2011 11:49 PM in reply to: Dennis_Jeffrey
bloody sucks, our download for Vault 2012 has been there for days now, but no Inventor 2012. proper frustrating!
Cheers
Scott Moyse
Member
0 Kudos
Post 10 of 26
06-02-2011 08:41 PM in reply to: Dennis_Jeffrey
Hi, is there a fix for this as yet?
John
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
