There seems to be a bug with the frame generator in 2012. When using the frame generator, the G_L parameter in each part should always update based on the line that it is attached to from the skeleton. Well in 2012, the frame member's length will update (the B_L parameter updates), but the G_L parameter will no longer update, it stays at its original value from when it was first placed.
Has anyone else had this problem?
I've attached the file as an example. The Height of the skeleton was originally 121.370 in, and now it is 82 in. The parameter for the outside vertical legs will not update from 121.370 in to 82 in. I've tested this a few times with the same results.
Solved by bobvdd. Go to Solution.
Solved by alessandro.gasso. Go to Solution.
I am receiving an error message, that goes as follows
Runtime error 16
Expression too complex
The error occurs on the following line.
height = oCompOcc.Definition.RangeBox.MaxPoint.Z - oCompOcc.Definition.RangeBox.MinPoint.Z
You can safely remove that line. I am not using the height parameter.
But I would still like to find the cause of the error.
Can you send me a small data set or the ipt where it is failing on?
Txs
Bob
Bob we are getting this on only 1 of our computers (out of 3) and it is running 32bit Windows XP, the other 2 that don't get the error are both 64bit Windows 7, hopefully that helps?
Thanks Adam for pointing me in the right direction.
There is indeed something funky going on with subtracting Doubles on 32 bit machines in VBA.
No wonder that I did not see the problem as I am working on a 64 bit machine.
You can avoid the run-time error If you replace the line
with
Dim maxz As Double
Dim minz As Double
maxz = oCompOcc.Definition.RangeBox.MaxPoint.Z
minz = oCompOcc.Definition.RangeBox.MinPoint.Z
height = maxz – minz
I have updated both blog posts with the correct code now:
Bob
