All of a sudden, I am asked to migrate the dwg template. When I choose New, and standard.dwg, in the default directory, the message is "the template file you are using to create the new document needs to be migrated. Please open it and explicitly save it before using it to create any more documents". Under tools,Application Options, the default templates is listed as follows: %PUBLICDOCUMENTS%\Autodesk\Inventor 2011\Templates\. If I open up the standard.dwg and save it, I am not prompted to migrate. And I get the same message as above when I choose New Dwg. Any suggestions? Thanks in advance.Bill S
You might want to look at your project file and make sure you are not pointing to a different location in the project file settings for your template files.
Paul
