Inventor Forum
2011 .ipn animation recording problems
6 REPLIES 6
s1e2t3h4
970 Views, 6 Replies
I just installed IV 2011 and I am trying to record an animation in my .ipn file to a .wmv file. When I hit the record icon I give it a .wmv file name, hit save. Choose custom profile and set my bandwidth to (Custom) 500 and my pixel size to 1200 x 900 and hit OK. Then the animation dialogue box comes up and the record button is not depressed like it is supposed to be. I can record it with the default settings, but it looks horrible.
Thanks for the help.
- Seth
6 REPLIES 6
s1e2t3h4
in reply to: s1e2t3h4
What I left out is that it will not record with my custom settings. It worked in previous versions
JONOELLRICH
I have this same problem in 2012, but I can't get it to record at all, even with the stock settings.  Have you ever heard back on this issue?
Thanks!
Jon
MuddyNZ
I have just logged the issue with Autodesk. I have tried doing this on a couple of setups now and they all fail.
Jarrod Mudford
Technical Evangelist \ Applications Engineer
Manufacturing &
Process and Power Plants
AEC Systems Pty Ltd
jarrod.mudford@aecsystems.com.au
www.aecsystems.com.au
JONOELLRICH
Thanks for replying on this, I had meant to reply myself--I also wound up logging it with ADSK, and it appears to be related to the recent(ish) service pack. After I uninstalled the service pack I was able to record again. Couldn't live without sp1 for long, but temporarily going into control panel/programs and pulling that off did allow me to record.
Jon
MuddyNZ
in reply to: JONOELLRICH
Thanks for that. Definitely fixed the issue.
Jarrod Mudford
Manufacturing &
AEC Systems Pty Ltd
Our development is creating an hot fix for this problem that should be available in the next weeks.
In the meantime, I hope you can find useful the workaround from the blog post below.
http://beinginventive.typepad.com/being-inventive/2011/09/unable-to-create-avi-from-ipn-files-after-...
Thanks and regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
