When I have an assembly open and I right click on a part, there is about a 4 to 5 second delay until I get the context menu. The second time that I right click on the same part, the menu comes up almost instantly.
Does not matter if it is a "large" or "small" assembly. See the same lag. Here is a link to a short video http://screencast.com/t/lfyZc3Xtzq.
I have tried using different projects files and disabled the "Quick File Open" in app options. Neither made any difference.
Hardware setting set to "Performance". Using nvidia driver 257.21 and running a GTS 250 card. I have the advantage sub pack #2 installed.
Very annoying and not something that I saw in 2010.
Any clues to why this is happening?
That got the delay out, but now my vault brwoser is gone....(yes I am in a vault project).
To get the vault menu back, I had to do a Vault Repair Install. Now the vault browser is back, but so is the delay......
Sounds like the problem is in the vault browser. Any suggestions???
I have the same problem on W7 64bits with Inventor 2011 SP2 + Vault 2011 SP2 :
Of course, I'm using Vault Project.
When I disconnect on Vault, this problem disappears ???
I don't have this problem on the same vault server with a XP32 bits OS with Inventor 2011 SP2 + Vault 2011 SP2.
Have you got some ideas ?
Windows 7 x64 -
12 GB Ram
Xéon 3ghz
nVidia Quadro 2000
Inv R2011+Adv. Sub. Pack, SP2
Vault 2011 SP2
